A/C Gurus have a ?
Old Jul 16, 2008 | 08:27 PM
Slick Rick's Avatar
Slick Rick
Default A/C Gurus have a ?
Okay check this out. I just did a check for codes no codes or history codes all except my HVAC. Im getting BO 361 H C. Left actuator feedback short. The funny thing is my A/C is working perfectly. All modes work temp controls work. I also can here actuators working when I turn on the key. I have it set at 68 now and blows air in at a cool 40 degrees, from all vents. Is this a code that will clear on its own after 50 cylcles? I have had the problem in the past blowing hot air through the drivers vent and just unhooked battery for awhile and everything has been fine. What do think leave it alone or what?
Old Jul 16, 2008 | 10:11 PM
Plasticfan's Avatar
Plasticfan
You know that old saying "If it ain't busted don't fix it".
Seriously though, heres more than most would want to know about those pesky actuators:
http://forums.corvetteforum.com/show...ighlight=B0361
BTW, it takes 100 fault free ignition cycles to clear that code from history.
Old Jul 16, 2008 | 10:31 PM
at88mph's Avatar
at88mph
From: The artist formally known as NONO5.0 Mobile, Al
I believe that you can remove it by holding the reset button after going through all the codes. Try going to the HVAC section via the DIC and hold down the reset. The display will read 'no codes'
To A/C Gurus have a ?
