need help
Old Jul 20, 2008 | 01:16 AM
RIPPENIT's Avatar
RIPPENIT
Default need help
how do you add trans fluid to a automatic trans i have a 2000 it has no dip stick
Old Jul 20, 2008 | 07:36 AM
BlackZ06's Avatar
BlackZ06
It has no dipstick because the transmission is in the rear of the vehicle. You need to jack the vehicle up and hold it level (best/easiest to use a lift). With the engine running you unscrew the plug marked FILL and add ATF until it is at the level of the fill port. Install the plug and you are done.
WARNING: You will be working very near to hot exhaust pipes, and overfilled fluid will be very hot. Wear appropriate protection (gloves and eye protection at a minimum).
Since you felt the need to point out the car doesn't have a dipstick for the tranny ... I'd recommend you take the car to the dealer (not Jiffy Lube) and let them do this.
