Z06 alignment specs
Old Dec 28, 2001 | 04:41 PM
EdwardETraylorIII's Avatar
EdwardETraylorIII
Default Z06 alignment specs
Gentlemen, I'm going to head over to the Chevy dealer and see if they are aligning my car to the proper specs. Would you be kind enough to post (per Chevrolet/GM) what the proper specs are for Z06 4 wheel alignment?
Thanks!
Old Dec 28, 2001 | 05:19 PM
EdwardETraylorIII
Default Re: Z06 alignment specs (EdwardETraylorIII)
ttt
Old Dec 28, 2001 | 05:25 PM
Patches's Avatar
Patches
From Ken Fichtner:
Z06 Wheel Alignment Specifications
Front Alignment Specs Service Allowable Service Preferred
Front Individual Toe +0.14 to -0.06 degrees +0.04 degrees
Front Sum Toe +0.28 to -0.12 " +0.08 "
Front Individual Camber +0.50 to -0.70 " -0.20 "
Front Cross Camber +/- 0.25 " within 0.50 "
Front Individual Caster +6.4 to +7.4 " 6.9 "
Front Cross Caster +/- 0.25 " within 0.50 "
Steering Wheel Angle +1.0 to -1.0 " 0.00 "
Rear Alignment Specs Service Allowable Service Preferred
Rear Individual Toe +0.09 to -0.11 degrees -0.01 degrees
Rear Sum Toe +0.18 to -0.22 " -0.02 "
Rear Thrust Angle +0.10 to - 0.10 " 0.00 "
Rear Individual Camber +0.32 to -0.68 " -0.18 "
Rear Cross Camber -- within 0.50 "
Ed
Old Dec 28, 2001 | 05:36 PM
EdwardETraylorIII
Default Re: Z06 alignment specs (Patches)
Hey Patches, thanks a lot! I did a search but didn't turn anything up!
Thanks again!
Old Dec 28, 2001 | 06:54 PM
Patches's Avatar
Patches
No sweat. Remembered seeing it listed there recently.
Good luck.
Ed
To Z06 alignment specs
