Lousy mileage
Old Jul 21, 2008 | 12:35 PM
vetteman5555's Avatar
vetteman5555
3rd Gear
Default Lousy mileage
I have a 97 C5, which I had a 3.42 rear end and an after market torque converter installed in. Before these were installed I averaged somewhere in the area of 25-27 MPG. Now I am lucky to get 18 MPG on a trip. Any ideas? Would these modifications change the MPG this much? How can I improve the MPG?
Old Jul 21, 2008 | 12:53 PM
AFTRBRNR's Avatar
AFTRBRNR
Switching the gears will drop the mileage significantly in an automatic. I went from around 28 to 20 switching from a 3.15 to 3.73. I did make a mistake and descreen my MAF which cause issues. I replaced the MAF with a new factory piece and milage jumped back up to 24.
Bottom line, gears will affect mileage. Think; what RPM were you at before and what are you at now? Mine increased 450 RPM (that means more fuel).
Old Jul 21, 2008 | 01:29 PM
EStreeter's Avatar
EStreeter
I went from a 3:15 to a 3:42 and it didn't effect my mileage that much. I still average about 28 on the highway. RPMs at 70 mph cruise went from 1950 to about 2100.
When you did the stall converter, did you reprogram the computer for lock up speeds. Once the converter locks up it should drive exactly the same as a lower stall converter when cruising. Maybe the converter is not locking up properly - that will effect the mileage big time.
Old Jul 21, 2008 | 07:46 PM
itzza427's Avatar
itzza427
I would suspect the converter too and depending on how "loose" it is,it will have an effect on MPG.
Old Jul 22, 2008 | 04:25 PM
vetteman5555
3rd Gear
Default lousy mileage
what if I go back to the orginial converter? Will that help with MPG without reducing the benifits of the 3.42?
Old Jul 22, 2008 | 04:55 PM
yankeevetteconvert's Avatar
yankeevetteconvert
The TC will not reduce MPG at highway speeds.Once the TC locks there is no difference in any converter. Make sure your TC is locking up at 34/36 mph in OD.My guess is that it is not locking up and this is the cause of your low milage.
I am running 3.73 gears with a 3600 Stall TC and I'm getting 27/28 mpg on the highway.I am also running 11.2 CR and this is making up for the 3.73 gears.I also have my TC locking up at 34 mph.
Old Jul 22, 2008 | 05:03 PM
EStreeter's Avatar
EStreeter
I would check and make sure your stall converter is locking up before you go through the expense of changing it out. The lock up is controlled by the computer or you could have valve or pump problem in the trans.
I have the stock converter and 3:42 gears and the car feels strong but it is probably not as good as if it had a higher stall converter.
Old Jul 23, 2008 | 01:29 AM
itzza427's Avatar
itzza427
OOPS! I forgot/missed the part where he mentioned "on a trip" I wa thinking a high stall would kill MPG in the overall picture (where stop and go city driving entered the picture) Sorry!!
Old Jul 23, 2008 | 11:32 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
97 C5!! Whats the mileage? What maintenance has been done to your C5 over the years? Stuff like primary O2 sensors, plugs & wires, air filter etc.....
I also agree that if the converter is not locked up in OD, your fuel mileage would suffer. What RPMs are you pulling at 30-40-50 and 60 MPH on a straigh stretch of level highway. That info will allow others with an auto to let you know if the TC is locking up correctly.
You can also find someone one in your area that has EFI Live or HP Tuners and ask them to data log your car. That will show you a LOT
You can look at O2 sensor preformance (switching), LTFT's MAP, MAF and Transmission data. All in one driving session!
BC
Old Jul 23, 2008 | 01:31 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
I agree with Bill---sounds like you have other issues at play here--You need to get it over to a tuner and have them run some data logging to check the lock-up, 02's etc.----Installing a stall converter takes specific tuning in order for it to work properly--If for example you don't max out the misfire tables, you'll get full line pressure when it throws codes or goes into a limp mode--horrible on mileage--I have a 2600 stall and a 3.42 on my '98 and my milage went from 28 to 26----
Old Jul 23, 2008 | 03:56 PM
vetteman5555
3rd Gear
Default Good mechanic
I live in the DC northern VA area. Does anyone know of a good shop to check this out for me? Also, has anyone any experience with a super chip?
Old Jul 24, 2008 | 12:49 AM
striper's Avatar
striper
Well, not only are those mods affecting your gas mileage, I would also be monitoring your trans temps. If your converter is slipping that much you're also making your trans fluid run hotter. An extra trans cooler might be in your future.
Old Jul 24, 2008 | 01:21 AM
One Nut's Avatar
One Nut
as am I same set up -11.2 cr although i de screened the MAF that gave the throttle a little more snapp
To Lousy mileage
