Wheel lock wrench missing HELP!!!!!!!!!!!!!!!!!!
Old Dec 28, 2001 | 10:28 PM
rbhanlon's Avatar
rbhanlon
Default Wheel lock wrench missing HELP!!!!!!!!!!!!!!!!!!
I got my 2000 used no wheel lock tool. Can the dealer find out which tool I need to take off my wheels? :confused:
Old Dec 28, 2001 | 11:39 PM
MelloYellow's Avatar
MelloYellow
Default Re: Wheel lock wrench missing HELP!!!!!!!!!!!!!!!!!! (rbhanlon)
They should be able to break the locks off and destroy them without hurting the studs or wheel. You'll need to buy a new set tho.
Old Dec 28, 2001 | 11:44 PM
Supercharged's Avatar
Supercharged
From: 26 NM out the 304 radial of the ORD VOR Illinois
Did your dealer look in the proper place, which is in it's little compartment under the small left side cover in the rear.
Old Dec 28, 2001 | 11:48 PM
vetteshop's Avatar
0vetteshop
Former Vendor
St. Jude Donor '13
The dealers have a master set to remove locks...There is less than 10 different wheel lock patterns on the C-5 :smash:
Old Dec 29, 2001 | 12:20 AM
JWD01's Avatar
JWD01
Default Re: Wheel lock wrench missing HELP!!!!!!!!!!!!!!!!!! (C-5 TECH)
If all else fails, take a 1/2" drive socket that is a hair smaller than the lock and use a hammer to pound it onto the lug nut. Once it is on, use a ratchet or breaker bar to remove the lock. This works really well for removing Magard locking lugs if you don't have the key. :yesnod:
Old Dec 29, 2001 | 01:49 AM
MelloYellow
Wonder why my dealer doesn't have a master set? They work on enuff C5's...
Old Dec 29, 2001 | 01:59 AM
BA2's Avatar
BA2
Wheel locks?
:lol:
Old Dec 29, 2001 | 02:23 AM
oceanaire's Avatar
oceanaire
Default Re: Wheel lock wrench missing HELP!!!!!!!!!!!!!!!!!! (MelloYellow)
IMHO dealers suck. Go to a real corvette shop.
Old Dec 29, 2001 | 01:33 PM
ditchdigger's Avatar
ditchdigger
I went to the dealer and the service writer handed me a box of different sockets and said for me to find one that works and that way he wouldn't have to write it up and charge for a mechanic. About the only pleasant experience I have ever had with a service writer.
Old Dec 29, 2001 | 06:30 PM
MelloYellow
Default Re: Wheel lock wrench missing HELP!!!!!!!!!!!!!!!!!! (oceanaire)
Which one you thinking of?? S. FL?
Old Dec 29, 2001 | 07:33 PM
skydive69's Avatar
skydive69
Default Re: Wheel lock wrench missing HELP!!!!!!!!!!!!!!!!!! (Supercharged)
Thanks Supercharged, I had mine bouncing around until based on your post I went out and found that little notced compartment. :D
Old Dec 29, 2001 | 08:23 PM
rwlc5's Avatar
rwlc5
Default Re: Wheel lock wrench missing HELP!!!!!!!!!!!!!!!!!! (skydive69)
Can someonr tell me exactly where the key should be. I looked in the left side compartment, but I don't see any place where the key might be stored. Thanks
Old Dec 29, 2001 | 09:05 PM
Paradigm's Avatar
Paradigm
Default Re: Wheel lock wrench missing HELP!!!!!!!!!!!!!!!!!! (rwlc5)
Small indentation on the right hand side.
Old Dec 29, 2001 | 09:09 PM
Supercharged
I think this info is in the owners manuel, but remove the small (12"x18" aprox.) cover on the left side. The lip on the left of the opening is a couple of inches wide. Toward the rear of this 2" strip is a little cubby about 1"X2", just big enough for the wheel lock key.
Old Dec 31, 2001 | 09:21 AM
FlaVert's Avatar
FlaVert
Snap-on makes a wheel lock defeater socket. I bought and used one to get mine off a few weeks ago. Worked great. Ordered a new set of regular lug nuts from gmpartsdirect.com, and now I don't need the stupid wheel lock key! :D
To Wheel lock wrench missing HELP!!!!!!!!!!!!!!!!!!
