spark plug heat sleeves
Old Jul 23, 2008 | 07:45 PM
Kamil D.'s Avatar
Kamil D.
Default spark plug heat sleeves
I’m about to change my spark plugs and wires, should I buy spark plug heat sleeves, and if yes were can I get some
Thank you.
Old Jul 23, 2008 | 08:06 PM
Kamil D.'s Avatar
Kamil D.
Old Jul 23, 2008 | 08:17 PM
ShadowLight's Avatar
ShadowLight
I am running no sleeves since I did my headers and I'm doing just fine!
Considering putting them on for a NASA event...
Old Jul 23, 2008 | 09:00 PM
MagRedConv's Avatar
MagRedConv
[QUOTE=ShadowLight;1566426749]I am running no sleeves since I did my headers and I'm doing just fine!
QUOTE]
Same here.
Old Jul 23, 2008 | 09:06 PM
vsocks1's Avatar
vsocks1
Why not use the stock ones?
Old Jul 23, 2008 | 09:19 PM
vettekidc5's Avatar
vettekidc5
i just took the heat sleves off my old wires and swaped them onto my new ones.. I figured It couldnt hurt and It worked fine...
Old Jul 23, 2008 | 10:24 PM
tiojames's Avatar
tiojames
I got mine from Summit when I put the headers on. They don't list them in their catalog for C5s, but when you call they have them available.
Old Jul 23, 2008 | 10:25 PM
Doug@MorosoPerformance's Avatar
0Doug@MorosoPerformance
Former Vendor
I use the stock heat shields with MOROSO wires, works great with my headers.
Old Jul 23, 2008 | 10:28 PM
OhioDave's Avatar
OhioDave
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16'17-'18-'19-'20-21
Jegs has several choices.
www.jegs.com
Old Jul 24, 2008 | 08:48 AM
ShadowLight
Had some trouble getting my wires to connect properly after swapping headers, so I figure I better leave well enough alone.
I have done a half-day road course event with no shields and doing just fine as well.
Old Jul 24, 2008 | 11:41 AM
Kamil D.'s Avatar
Kamil D.
I did not know they come with one, its already on the wirers ?
Old Jul 24, 2008 | 01:52 PM
vsocks1's Avatar
vsocks1
My 2003 Z06 OEM wires had metal heat shields on the spark plug boots. When I installed haeders I left them on. Don't recall hearing the OEM replacement wires come with them, they are probably a seperate part. Someone else may know this and chime in!
Old Jul 24, 2008 | 06:04 PM
bigbadbevo's Avatar
bigbadbevo
I think Kamil is referring to the KoolSox type of sleeves that protect the length of wire. The OE metal heat shields protect the boot portion of the wire but not the wire itself.
I am running KoolSox w/ my LG Pros because I have wires w/ angled boots (Magnecor) and the OE heat shields don't fit . From what I've observed there's adequate clearance between the wires and the header tubes that I probably did not need the KoolSox. Since I had already purchased them, I threw them on.
IMO, unless your wires are coming into direct contact w/ the headers I don't think they're necessary.
Old Jul 24, 2008 | 06:43 PM
fixvet's Avatar
fixvet
When I installed my 8.5mm MSD wires, I put back on the metal heat protectors then some KoolSox over the whole lenght of the wires. I don't have headers, but like the look! I think I bought all my stuff from Jegs.
To spark plug heat sleeves
