Pushrod length?
Old Jul 24, 2008 | 03:13 PM
nj02vette's Avatar
nj02vette
From: Marlton. Increasing performance one speeding ticket at a time! NJ
Default Pushrod length?
What are the lengths of the pushrods on LS1's and LS6's.
Just saw from GMPP that there appears to be only one p/n for all pushrods, LS1, LS2, LS3, LS6 and L92.
10238852 7.325"
Is this correct. I thought the Z06 cam had a smaller base circle and pushrod length was dependant on that. Plus, I thought the standard push rods were 7.40"?
Anyone clear up my confusion?
Old Jul 24, 2008 | 03:51 PM
J.R.'s Avatar
J.R.
To my knowledge - 7.400
A recent post indicated LS3 was also 7.400
I am running 7.350 due to milled heads / Cometic gasket and the alignment is perfect so 7.325 sounds too short for a stock LS1/LS6 setup unless it is in conjunction with a different lifter.
Old Jul 24, 2008 | 03:56 PM
vettenuts's Avatar
vettenuts
Actual gauge length I measured was 7.385". The pushrods are the same because the base circle is smaller but the valve stems are taller to balance it out.
Old Jul 24, 2008 | 06:51 PM
verano29's Avatar
verano29
I didn't measure my stock pushrods but my 7.4 hi tek pushrods were noticably longer than the stockers
To Pushrod length?
