service engine soon
Old Jul 24, 2008 | 01:30 PM
rocco666's Avatar
rocco666
Default service engine soon
Every so often I get the service engine soon displays in my DIC. when I first got the c5 vert this happend quit often along with the fuel gauge going to empty problem. well I researched and stsrted using Chevron gas only(HIGHEST grade) and every other tank or so i would put in a bottle of techtron gas treatment,,,, both problems went away.... well i recently changed my accordian air intake to a smooth coupler intake,,, and now the service engine soon message has started to reapear again every so often,,,, any ideas......
Old Jul 24, 2008 | 01:40 PM
hotwheels57's Avatar
hotwheels57
Possibly a leak somewhere in your intake system. I had the same issue with my car when I installed a rigid after market coupler.
I found there was a pucker on the bottom side of the coupler where it is supposed to slip over the OD of the throttle body. The clamp went over it and tightened down, but the pucker obviously didn't seal. I found it with a small mirror.
I used a little lubricant (WINDEX) along the ID of the coupler and re-installed it, twisting it to insure there was no pucker. I confirmed it with the mirror.
But, it could be non related to the intake. Check the codes (H and C) on the DIC and figure out what they refer to. It could be as simple as not tightening your fuel cap, or not resetting you oil life monitor to 0% after an oil change.
Old Jul 24, 2008 | 02:04 PM
LoneStarFRC's Avatar
LoneStarFRC
Re: Check Engine Light - Post your DIC code(s). At least then someone may be able to point you in the right direction.
Old Jul 24, 2008 | 02:24 PM
rocco666's Avatar
rocco666
Default ohhhhhhhhhhh
You know what,,,,,, I didnt reset my oil life meter when I had the oil changed ,,,, I bet if i look at the dic and oil life it will be at 0% left,,, thanks guys, Ill check when i get home and let yall know...
To service engine soon
