transaxle mount
Old Jan 17, 2010 | 10:43 AM
  #161
deadcafe's Avatar
deadcafe
Originally Posted by Its_Go_Time
It's interesting to note that the FWD drivetrain in my glorious '95 Intrepid is actually quite analogous to our Vettes torque tube set-up. It's got a longitudinally mounted engine with the transaxle mounted solidly to the engine. I rebuilt the engine a couple of years ago, and when I got it back together, I drove it around the block a few times with no hood on it to make sure all was well. As I was driving, I could look down at the entire drivetrain system. When you accelerate the car, these systems have only one torque applied to them. Its torque as seen in the side view, not the front view. An extreme example is when a car lifts its fronts. In a torque tube C5, the engine/torque tube/trans/diff unit lift, and carry the rest of the car with it. When you jam it, the torque applied to the drivetrain tries to spin the engine UP arount the rear wheels, not to the left or right. A little freaky, and a lot unusual on front engine RWD cars. On our C5's, the engine is far from the rear wheel centerline, so the torque developed has a hard time delivering big displacement. Not so on my Intrepid. The engine/transaxle mass is distributed very close to the wheel centerline. Result: The nose of the engine pitches way up when I nail it. Not left. Not right.
In my humble opinion, the mount that this thread was originally about is a beautiful solution to a problem that never existed. Straight up.
Ummmmm,,, What??
Old Jan 17, 2010 | 11:06 AM
  #162
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Originally Posted by deadcafe
Ran like butter prior. Now the pretty much solid transaxle mount from VBP has no forgivness. I will probably end up replacing it with the rubber stock mount.
Same clutch assembly as my friends 03 Z06 and his car is smooth.
Again your friend does not use the Pfadt mount. Put it in his car and see what happens.
- Race vehicle parts are notorious for causing / creating vibration generated noise.
- Go and buy a thin sheet of rubber and stick it in between the metal to metal portion of the mounts.
Go look up McMaster-Carr as they sell it in various sheet thickness. 1/8 or 3/16 should be good.
Old Jan 17, 2010 | 03:38 PM
  #163
deadcafe's Avatar
deadcafe
So what you are saying I should do is place a little bit of rubber in between the pinch points of the Mount and the carriage and the mount and the transaxle? maybe a bit of adhesive?
Old Jan 17, 2010 | 04:12 PM
  #164
ajg1915's Avatar
ajg1915
St. Jude Donor '08
I have the same similar mounts as you except for they are the C6 rear Pfadt transmission mounts.
Where there is steel on Aluminum in the center mount, throw in a layer of rubber and will cut down on the vibrations that you are hearing and feeling.
I'm going to do the same thing on mine. I'm putting in a C6 Z06 differential and tranny into my C5 from ny left over project car.
Tony
Old Jan 17, 2010 | 04:29 PM
  #165
deadcafe's Avatar
deadcafe
Tony
We will se what happens I just bought a .125 thick x 2" x 36" piece of EDMP High Strength Rubber for 33 bucks from rsr.com I will try it it sounds like a good idea. Not to mention it makes sense.
Old Jan 17, 2010 | 04:55 PM
  #166
lionelhutz's Avatar
lionelhutz
That's not a bad analogy, The torque tube does get rid of the side engine torque a RWD car usually experiences. The movement you see is probably due to a lot of FWD cars having soft top engine mounts that allow movement.
But still, the shorter distance between mounts does cause a FWD drive train to rock more. The torque at the axles is in ft-lbs. A FWD car with say 2ft between top and bottom mounts will turn 200ft-lbs of axle torque into 100lbs of force at the mounts. A C5 with say 5ft between mounts will turn 200ft-lbs of axle torque into 40lbs of force at the mounts. In the C5 case, there would be 40lbs pushing down on the transmission mount and 40lbs lifting on the engine mount.
Of course, in the above I'm just making numbers up. I really don't know the actual distance from front to rear mounts on the C5.
Peter
Old Jan 17, 2010 | 05:00 PM
  #167
lionelhutz's Avatar
lionelhutz
I don't see that as a great solution or you could call it an incomplete solution. The mounting bolts would have to be left a little lose for the rubber to have an effect. Then, under power the rubber would compress and let the nuts on mount possibly come lose. Also, the side with the rubber may absorb vibrations but the side with the nuts against the cross member would still vibrate and they can now move so it would wear too.
You need to make a plate and sandwich both sides of the cross member in rubber for this to have any hope of helping. Use lock nuts so the bolts can be snugged but not cranked right tight.
Peter
Old Jan 17, 2010 | 06:44 PM
  #168
deadcafe's Avatar
deadcafe
Peter
I agree, at best it is a modification to a stout mount that will decrease the full vibration that is occuring. I bought a 2"X36" piece of some killer rubber so depending on the space between the carriage and the mount and the Transaxle and the mount I may dbl it up. Any deflection offered will be an improvement. lionelhutz when I say the vibration is bad I mean it. It is constant at the mid level RPM mariofromnewyork can agree with that statement being he drove it this weekend.
If the fix does not work I will be on here begging someone to donate a mount for minimal cost and I will pay for shipping. I am doing what I can to keep ridgity but willing to return to stock if I have to.
Old Jan 18, 2010 | 12:29 AM
  #169
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Peter
Well in my case with the C6 mounts it would be a sandwich since it would be between the cross-member and the actual transmission mount.
The Pfadt mounts use poly lock nuts so they won't be coming loose.
