Procedure for flushing brake fluid?
Suck out the old brake fluid from the MC. Replace with new brake fluid in MC, Not power bleed tank.
Put on the Power bleeder cap and pump up to 18-22 psi, and bleed each caliper.
Start in the rear, Do the rear two, then check the MC for fluid. Replace as needed. Pump the brake peddle a few times too assure it is solid.
Do the front two calipers.
Dont let brake fluid splash it will eat paint
Good Luck
Bill
Bill
There is one other way. But I dont recommend it.
Done it several times to ppl who have let their MC run dry.
Do the normal bleed, put the wheels back on and go for a very very slow drive down the road or street and back maybe 5 mph, no more. Pump the brakes a few times, you will have to as you wont have much of a brake. and the peddle will go to the floor.
Then bring or roll the car slowly back into the garage and put back on jack stands, and do a full system flush again. again MAKE sure the MC does not run dry
After this next full bleed the brakes should be good as new with a nice firm brake peddle.
As I mentioned I have done this 3 - 4 times and it worked just fine. Even at the track so the cars did stop very well from 130 mph.
Now that was just me, as you know I am a bit
and like to go bed brakes in just to do those very hard stops from 80 or 100 mph down to 5 mph. ( wonder why my wife wont go with me when I bed brakes in ?)
Tech II would be the safest way too assure the lines are fee of air
