Dual Zone A/C Upgrade
Old Jul 25, 2008 | 02:49 PM
Glen Green 65's Avatar
Glen Green 65
Default Dual Zone A/C Upgrade
My 2001 coupe does not have the dual zone A/C. Has anyone ever done a conversion from manual to electronic dual zone. If so, any suggestions.
Old Jul 25, 2008 | 03:10 PM
95BlueBomber's Avatar
95BlueBomber
I checked on this as well... I think it takes a little more work than you would expect. There are a few misc. parts that are involved then what I thought.
Old Jul 25, 2008 | 04:56 PM
glkfam's Avatar
glkfam
Default Same thing
I to looked into this and I believe there are more parts to change then you think. First I know the wiring plug for the back of the head unit is different. So a harness change might be in place right up front. Then I believe there might be changes with the duct doors. I am curious to see if someone ever tackled this. The only thing I can say is a lot of guys chime in with some problems on the electronic head, and I haven't heard any problems, to date with the non-electronic head unit. Hope someone else has input on this.
Old Jul 25, 2008 | 05:51 PM
timemender's Avatar
timemender
I have the dual zone in both C5’s. Personally I think it is over rated with great potential for malfunction.
I find myself adjusting the temperature up and down a little while driving, just like I do in my other vehicles with their non-automatic systems.
Old Jul 25, 2008 | 09:30 PM
LoneStarFRC's Avatar
LoneStarFRC
Aside from the expense and complexity, the whole reason d'etre of the CJ2 in a car as small as the Corvette is ridiculous to begin with.
There's also the ongoing problems with it too. Try a search and be prepared for a long read.
Trust me, you're much better off with the C60.
Old Jul 26, 2008 | 06:32 AM
tom_c5's Avatar
tom_c5
Don't waste your $ or your time on dual zone. I have it in my C5 and it's lame! Think about it, how could it possibly control temperature at two different levels in a small closed enviornment. Yes, the vents do blow slightly different temps but nothing really noticeable.
Old Aug 8, 2008 | 01:15 PM
Glen Green 65
Thanks for all of the responses. I have since learned that in addition to the defroster and a couple of other vents under the dash the BCM must be changed. This = large bucks. I have decided to put the $ into performance upgardes.
Old Aug 8, 2008 | 07:54 PM
inrealtime's Avatar
inrealtime
Exactly what I did. I initially wanted it as well, since my wifes' Lexus has the dual zone, but after researching it, not only is it alot of work to change, but alot of people that have the dual zone don't like it.
Old Aug 8, 2008 | 11:05 PM
jdmvette's Avatar
jdmvette
Night Owl for life
from what i've read in the past, changing from the manual AC to the DZ is pretty much impossible.
Old Aug 8, 2008 | 11:54 PM
Z06ster's Avatar
Z06ster
Same here! If there were a way to convert the Dual Zone to a manual system, I'd do it in a heart beat. I have already had to repair a failed actuator door... $700 donation to the dealership (although this was before I was a Forum member... probably could have done it myself had I been on here!!)
Way to go for sure
To Dual Zone A/C Upgrade
