shifter knob
Old Jul 26, 2008 | 09:45 AM
roadster red's Avatar
roadster red
7th Gear
Default shifter ****
Does anyone have any idea how in the world to take a six-speed shifter **** off? I ordered the Hearst six-speed shifter **** and can't get the old one off? Is there a trick to this?!
Wayne
Old Jul 26, 2008 | 10:22 AM
LoneStarFRC's Avatar
LoneStarFRC
Wayne
Search is your friend.
Old Jul 26, 2008 | 10:38 AM
Doug@MorosoPerformance's Avatar
0Doug@MorosoPerformance
Former Vendor
Pry off the plastic cover. Under the cover you will see an L shaped key, pry the key up and out. Unscrew the shift ****. It is easy "IF" the key comes out. It can be a real bear requiring penetrating fluid, vice grips, hammers, ect. Good luck.
www.moroso.com
Old Jul 26, 2008 | 11:25 AM
Novakain1970's Avatar
Novakain1970
also watch you dont smack the face of the radio by accident like i did, now i have to replace one of the buttons
Old Jul 26, 2008 | 12:06 PM
roadster red
7th Gear
Thanks a lot! I'll try it right now.
Wayne
Old Jul 26, 2008 | 12:40 PM
gairno's Avatar
gairno
www.moroso.com
Also you may have a few unwanted words to fly around trying to get the key out. Can be a real pain in the but. Good Luck.
Old Jul 26, 2008 | 01:27 PM
sperkins's Avatar
sperkins
It's a royal pain. You have to have a set of needle nose style vise grips to clamp onto the pin. It took two of us to do this job on a buddys car and we had to use a block of wood and a hammer.
Try these links:
http://www.stl-vettes.com/Home/Shifter.asp
http://corvetteforum.cc/techtips/vie...D=34&TopicID=1
Old Jul 26, 2008 | 01:39 PM
TEXHAWK0's Avatar
TEXHAWK0
I made a special tool to remove mine by bending a piece of flat bar, and filing a slot in it to match the ears on the key. Could be that I have too much time on my hands, but I did not smash any radio buttons, break any glass, or knock the mirror off.
Old Jul 26, 2008 | 09:20 PM
sperkins's Avatar
sperkins
Smartass.
Nah...great idea. You should immediately pull these pictures from the internet and market that thing.
Old Jul 26, 2008 | 10:18 PM
ssdeuce's Avatar
ssdeuce
I used a flat screw driver no problem.
Old Jul 26, 2008 | 10:23 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
Obviously you did it wrong then.
To shifter knob
