Can't open driver door
Old Jul 26, 2008 | 10:55 AM
slippery's Avatar
slippery
3rd Gear
Default Can't open driver door
Is ther any way to manually open the drivers door. Both inside and outside door handles not working. Need to get door open to remove inner panel and see what needs to be fixed. Thanks in advance
Old Jul 26, 2008 | 11:56 AM
c5streak's Avatar
c5streak
Make sure the door is unlocked, with the key if your switch isn't working.
Go in from the passenger side and roll down the drivers window. Now, with a flashlught, look down in side the door at the latch assy. You will see an orange plastic retainer about 1/2" sq at the front of the latch assy. It holds the rod from the outside handle, onto the latch. I measured it on my coupe and it is 13" down from the w/strip on top of the door. Get a thin dowel, or metal rod at least that long, and push the orange retainer down to open the door. I cut the bottom portion of a thick plastic coathanger off, and it was just long and stiff enough. Make sure the door is unlocked or it won't work.
Old Jul 26, 2008 | 01:22 PM
slippery's Avatar
slippery
3rd Gear
Thanks for the help. Door opened, now I can fix solenoid/lock problem.
Old Jul 26, 2008 | 01:48 PM
TEXHAWK0's Avatar
TEXHAWK0
For the door handle not to work, wouldn't the actuator rod have had to come off of the latch assembly? Just curious why neither manual handles would not open the door, unless the door was locked.
Old Jul 26, 2008 | 02:24 PM
Novakain1970's Avatar
Novakain1970
Pop the hatch and climb in through the back
To Can't open driver door
