c5 shifter, looking for a hurst T knob
Old Jul 30, 2008 | 10:44 PM
vjjack04's Avatar
vjjack04
Default c5 shifter, looking for a hurst T ****
is there a direct fit for the c5 manual 6 speed?
Old Jul 30, 2008 | 10:56 PM
02gt350's Avatar
02gt350
i have a hurst T, but the hole is way to big. You can buy adapters to screw on the shifter. usually come with the handle
Old Jul 30, 2008 | 11:06 PM
vjjack04's Avatar
vjjack04
OK; so the adapters are pretty much standard?
Old Jul 31, 2008 | 12:08 AM
02gt350's Avatar
02gt350
that im not sure about. If you go into a shop or store, they shoudl let you take out and check on your car...most do anyway
Old Jul 31, 2008 | 03:53 AM
dieseldave56's Avatar
dieseldave56
Default No adapter needed , find zrchris .............
[IMG][/IMG]zrchris , forum member has reworked hurst shifter 2 inch black and white ball to fit the C5 shifter arm with 9/16-18 steel tap-cert . Very strong . I have both black and white plus the original Hurst T handle that chris also did his magic to, Good guy. He also has a Ebay auction http://cgi.ebay.com/ebaymotors/Hurst...spagenameZWDVW[IMG][/IMG][IMG][/IMG] Also Hurst never , that I know of , had a threaded adapter up to 9/16-18. 1/2-13 thread yes. Find zrchris using the search mode.
Old Jul 31, 2008 | 07:11 AM
Lancer033's Avatar
Lancer033
but to be honest, I got ride of my t-handle after a few weeks.
Old Jul 31, 2008 | 09:41 AM
DIXZ's Avatar
DIXZ
And I thought I was the only one that craved the "Old School" T-handle shifter!
I was not able to find one that is made for the Corvette, so I bought one with a 7/16 hole, drilled and tapped for 9/16 -18 thread. It works great, especially with the Fastbird line lock, as I have the one with the switch on the end. It is no where near the correct geometry for the C-5 shifter, but I am happy with it.
Something to think about before jumping on this is that the steel shift lever gets pretty hot and will transfer that heat to the aluminum handle after a while. I never noticed this while using the Hurst plastic round shift ****.
All in all, I am very pleased with this unit. It's just my way of bringing back a little of the '60's!
Old Jul 31, 2008 | 10:30 PM
vjjack04's Avatar
vjjack04
Thanks fellas, yeah I will probably by one local a tap it.
I long for the shifter feel I had in my '71 Barracuda when I was growing up. Plus they just say something about the good old days.
As for the heat, I already have a round aluminum ball; I just lay a hat over it when I am parked in the sun.
Old Jul 31, 2008 | 10:38 PM
Quick Silver Z's Avatar
Quick Silver Z
St. Jude 15 Year Donor
No-IL Events Coordinator
2025 C6 of the Year Winner - Unmodified
2019 C6 of Year Winner (appearance mods)
2018 C6 of Year Finalist
St. Jude Donor '12 thru '26
As much as I love the "Old School" Hurst T-handle shifter you have to be careful with that much "leverage". I once broke a shifter rod in two while attempting to powershift second gear! :o
Old Aug 1, 2008 | 01:21 AM
dieseldave56
Default Perforated T
I have noticed that the handle (T) does warm up. But I plan on perforating it to reduce weight and to address heat dissipation. I will then have it power coated.
Old Aug 1, 2008 | 09:43 AM
Calibur45's Avatar
Calibur45
I have the white hurst ball and love it
Best of luck to you finding one!
To c5 shifter, looking for a hurst T knob
