Tire Pressure reads-Lost
Old Jul 30, 2008 | 11:33 PM
kg54trains's Avatar
kg54trains
Default Tire Pressure reads-Lost
98 coupe has lost front and rear pressure reads by the DIC at the same time. Before I reset with a magnet might this be a different problem. No lost of battery power and electrical trouble.
Old Jul 31, 2008 | 10:09 AM
Doug@MorosoPerformance's Avatar
0Doug@MorosoPerformance
Former Vendor
If they are the original sensors they may need to be replaced. Over the last two years I have had to replace all four on my 99.
Old Jul 31, 2008 | 10:12 AM
jarsdad1's Avatar
jarsdad1
Try to reset them, first. Even if they are old, it is unlikely that all four would die at the same time.
Old Jul 31, 2008 | 01:50 PM
Former Vendor
You are correct, I read the post wrong. All four would not go out at once.
kg54trains - Have you checked for any codes? Also check fuse #27 in the instrument panel fuse box.
Old Jul 31, 2008 | 06:16 PM
Bakersfield's Avatar
Bakersfield
PM sent.
To Tire Pressure reads-Lost
