Fuel pump going bad?
But, I can say this. I've had several other GM products, trucks, Tahoe, Yukon, etc. and they all have had fuel pump issues. I believe the vette is similar in concept to those vehicles. The fuel is used to cool the pump. As such, it is highly recommended, to get max life from your fuel pump, to not let the tank get low. Keep at least 1/4 tank or more in the tank. Also, change the filter. Low fuel allows more junk to clog the filter. A clogged filter makes the pump work harder, and fail sooner. Of course, since the filter is in the tank on the vette, it's not an easy change, which is yet another reason to try and keep your fuel level up.
My first experience with the fuel pump issue was on the wife's yukon. She always ran the gas down to the fuel light and plus some. She burned up a fuel pump around 35,000-40,000 miles. That's when all this was explained to me. It was actually explained to me by a non-GM guy who did most of my work, and reiterated by the dealership guy.
And I can say, when those pumps are going bad, they scream. They just get louder and louder, then they fail. I remember that yukon just howling.
So, if you have a pump that's making lots of noise, my history suggests it is on the downhill side of its life.
Of course, remember, you've got two tanks in the vette. Also lots of posts about how those tanks work together.
I drove it later, and the noise went away. Also, I could not hear it when the car was running, just when the pump cycles with the ignition on.
I guess if it is not constant, there is no reason to worry.
