How to "pull the codes"
Old Aug 4, 2008 | 09:12 AM
cbruer's Avatar
cbruer
Default How to "pull the codes"
How do I do this?
thanks
Old Aug 4, 2008 | 09:20 AM
dougbfresh's Avatar
dougbfresh
https://www.corvetteforum.com/techti...D=26&TopicID=1
Old Aug 4, 2008 | 11:02 AM
Last C5's Avatar
Last C5
READING CODES ON THE C5
Turn the key to the ON position, but don't start the engine. Clear any present messages by pressing the RESET button. Hold the OPTIONS button down, and press the FUEL button 4 times. This will get you into the CODES section of the DIC. The computer will automatically display all the codes your car has created. It will cycle through each code every 3 seconds. Any code that ends in H is a history code (something that has occured in the past) but is fine now. Once the computer has finished going through all of it's codes, press RESET to enter Manual Configuration mode. It should start with a module and show "NO CODES" or "# CODES".
To optionally reset the codes once in manual mode, press and hold RESET until it displays "NO CODES". Press OPTIONS to go to the next module. Repeat the steps in this paragraph until you have reset the codes in all the computer modules. NOTE !! Only reset the codes IF you want to - it is NOT necessary to do this.
To How to "pull the codes"
