Torque settings
Old Aug 4, 2008 | 12:33 PM
Z Vette's Avatar
Z Vette
3rd Gear
Default Torque settings
Need a website for torque settings for a C5, also proper rotation of bleeding brake lines. Thank you
Old Aug 4, 2008 | 12:49 PM
slothy's Avatar
slothy
http://ls1howto.com/index.php?category=1
and
Brake Caliper Guide Pin Bolt / 23 Ft#
Brake Caliper Inlet Fitting / 37 Ft#
Brake Caliper Bleed Screw / 106 INCH #
Front/Rear Brake Caliper Bracket Bolt / 125 Ft#
Exhaust H Pipe to Overaxle / 37 Ft# *
Exhaust H Pipe Hanger Bolt / 37 Ft# *
Exhaust Hanger Bolts / 37 Ft# *
Exhaust Pipe Clamp Bolts / 37 Ft# *
Exhaust Manifold (first pass) / 11 Ft# *
Exhaust Manifold (final pass) / 18 Ft#*
Exhaust Header Bolts = Follow Manuf. Recommendation*
*All Header and Exhaust fasteners should be rechecked after 2-3 heat cycles or 1 week
Front Spring Retainer Bolts / 46 Ft#
Front Shock Lower Mounting Bolt / 21 Ft#
Front Shock Upper Nut / 19 Ft#
Front Sway Bar Clamp Bolts / 40 Ft#
Front Sway Bar End Link Nuts / 53 Ft#
Rear Spring Retainer Bolts / 46 Ft#
Rear Shock Lower Mount Bolt / 162 Ft#
Rear Shock Upper Mount Nut / 22 Ft#
Rear Sway Bar Clamp LOWER Bolt / 70 Ft#
Rear Sway Bar Clamp UPPER Bolt / 49 Ft#
Rear Sway Bar End Link Nuts / 53 Ft#
Shifter Base to Torque Tube Nuts / 22 Ft#
Shifter Insulator to Body Nuts / 106 Ft#
Wheel Lug Nuts (3 step) = 30/60/90 Ft# * ** ***
Wheel Lug Nuts (1 step) = 100 Ft# * ** ***
as for brakes search on here, i know there is a few years that require a different procedure (ie order in which they are bleed).
Old Aug 4, 2008 | 01:15 PM
BlackZ06's Avatar
BlackZ06
You need to fill out your profile ... your Model Year determines the bleed sequence.
To Torque settings
