Need some brake hardware specs...
Old Aug 4, 2008 | 01:15 PM
SEE3ER's Avatar
SEE3ER
St. Jude Donor '21
Default Need some brake hardware specs...
Rear brake caliper pin/bolts...is there a torq spec for these, and do you install with anything on the threads? ie: threadlock or anti-sieze, lubricants?
Thanks in advance!
Old Aug 4, 2008 | 01:18 PM
slothy's Avatar
slothy
Brake Caliper Guide Pin Bolt / 23 Ft#
Brake Caliper Inlet Fitting / 37 Ft#
Brake Caliper Bleed Screw / 106 INCH #
Front/Rear Brake Caliper Bracket Bolt / 125 Ft#
red loctite on the bracket bolts (125ftlbs)
Old Aug 4, 2008 | 01:29 PM
SEE3ER's Avatar
SEE3ER
St. Jude Donor '21
Great! Thanks!
To Need some brake hardware specs...
