i wanted to know if i did a intake swap on my 99c5 if i could use my stock throttle body on the ls6 intake or would i have to get a bigger one.
also if any one can tell me every thing i need for the swap to the ls6 intake thanks
if any one has an ls6 intake they are trying to get rid of for a good price pm me
No need for a larger throttle body. As far as the swap goes, you will need a Coolant Crossover Pipe kit.
The Throttle bodies are all the same. www.gmpartshouse.com has a listing of the parts you will need and is a great place. You will need a coolant tube and two coolant plugs. But, that is it. You could use the ones you have, you would need to take a dremal to the bottom of the intake to allow the coolant tube to run under it. I always think about doing that, but never have the time.
