Header difference 97-00 and 01-04
Old Aug 9, 2008 | 07:27 PM
02 super sport's Avatar
02 super sport
Default Header difference 97-00 and 01-04
Whats the difference between 97-00 and 01-04 headers.
Will LT's for a 97-00 fit an 01 without mod? I know the headers will fit, just looking for any mods that may have to be done.
I tried searching for it, but couldn't seem to find the differences.
Old Aug 9, 2008 | 09:56 PM
JPEAK's Avatar
JPEAK
The only difference is the location of the air tube fitting on the passenger side. The 97-00 headers air tube fittings is on the header pipe closest to the firewall, and the 01-04 have the tube located on the 2nd pipe closest to the firewall. Driver side are all the same for all years
Old Aug 10, 2008 | 05:37 PM
02 super sport
Thanks for the help
Old Aug 10, 2008 | 05:47 PM
hotwheels57's Avatar
hotwheels57
Are you certain that's the same for every long tube header manufacturer? I'm not questioning your knowledge, just whether everyone does it the same.
It might help if both the original poster and anyone who replies qualify which header systems they're referring to...
Old Aug 10, 2008 | 07:45 PM
Uncle John's Avatar
Uncle John
Its not the header manufacturer that determines the difference, its the air pipe location that the model years have that the manufacturer has to match up to. So to answer your question, yes, all locations are the same on all headers to fit that particular year of car.
Old Aug 10, 2008 | 07:49 PM
byte_me's Avatar
byte_me
In addition to the above AIR tube location, I also was under the impression that the Oil Dip Stick attachment point was on a different primary old vs. new.
Old Sep 30, 2013 | 11:04 AM
Darkrider02's Avatar
Darkrider02
So how do you modify a set of lt for 01+ and make it fit a 00?
Old Sep 30, 2013 | 11:37 AM
burbleflyer's Avatar
burbleflyer
St. Jude Donor '08
If you're talking shortie headers, you enter whole different world for '00 cars. There are two types for them depending on whether your came with pup cats.
Old Sep 30, 2013 | 01:24 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
YES!!! The oil dip stick and tube are DIFFERENT and mount in different areas. The early cars, the dip stick mounts to the exhaust manifold/ one of the exhaust tubes.
On the later cars, the tube mounts more forward and bolts to the cylinder head.
If it were me, I would have the AIR system tuned out and get a set without air tubes or have them eliminated or blocked off!
Old Sep 30, 2013 | 07:00 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
All the above is true and I agree with Bill
Old Oct 1, 2013 | 07:35 AM
s346k's Avatar
s346k
silly question but can't the dipstick tube be bent ? are they *that much different? maybe buy a tube for the appropriate header. asking for instance if a deal on headers came along but not the right year.
Old Oct 1, 2013 | 08:37 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
LOL!! I imagine anything is possible BUT,,, the complexity of the bends and the possibility of KINKING the tube makes it not worth trying. You would also have to weld on the correct mount bracket.
The Tube and Stick are a matched set. Do NOT try to use a early stick with a newer tube or vise versa.
Ive put BOTH tubes on my 02 ZO6 just to see if they would fit I have Stainless Works headers and it has the fitting on exhaust tube #6 to mount the early stick.
97 frame with stick between cyl 4 & 6
Remember,, the 2001+ stick mounts to the cylinder head to the rear of #2 exhaust tube>
Old Oct 1, 2013 | 09:34 PM
lionelhutz's Avatar
lionelhutz
The early dip stick tube can be mounted to newer headers by bending and cutting and drilling the bracket so it bolts to one of the AIR tube fitting bolts. Fairly simple to do if you have any kind of fabrication skills.
The later dip stick will fit with the earlier headers as is.
No need to get in a panic about the dip stick.
Old Oct 2, 2013 | 04:35 PM
Rx7Rob's Avatar
Rx7Rob
I made a dip-stick mounting bracket when installing non-emission ARH's on my 2000. I welded the bracket to the tube and it bolts to the head.
Old Oct 3, 2013 | 09:17 AM
Vato's Avatar
Vato
Mine had to be relocated in my 2000 when I put TTS's on
Old Oct 3, 2013 | 11:29 AM
KOZ's Avatar
KOZ
I just put a a set of 97-00 on a 02 two weeks ago. Fit with no issues, lucky me I had an old 00 air tube in the parts bin and swapped it out to make that fit, the one in the car had a bad valve anyway. The dipstick bolted right up to its original location.
To Header difference 97-00 and 01-04
