help with exhaust
Old Dec 31, 2001 | 11:04 PM
70 LS1's Avatar
70 LS1
Default help with exhaust
How much back pressure does tha LS1 need to run right? I am going to be running stock C5 manifolds, no cats and 2.5 inch dual chambered exhaust to the stock square tips.
Old Jan 1, 2002 | 05:33 AM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Default Re: help with exhaust (70 LS1)
Someone did remove the cats and picked up approx. 14 hp, not sure about required back pressure.
Old Jan 1, 2002 | 12:08 PM
carpe dm's Avatar
carpe dm
Can you get away with "no cats" in WA? They check here in AZ if you live in one of the large metro areas. I don't know about the C5, but I ran with a cat and straight pipe set-up on my C4 and it worked great;, the cat provided the needed back pressure. :)
Old Jan 1, 2002 | 12:20 PM
Paradigm's Avatar
Paradigm
I did the no cat routine when my car was stock and it fell on it's face. The bottom end response was weak, at best, and the throttle response was spongy.
Old Jan 2, 2002 | 09:41 PM
70 LS1's Avatar
70 LS1
Default Re: help with exhaust (carpe dm)
No cats is easy when it is a 1970 corvette.
To help with exhaust
