a shudder
Old Aug 10, 2008 | 03:24 AM
wettvette's Avatar
wettvette
Default a shudder
Hi guys, sometimes when i apply my brakes i feel a slight shudder in the brake pedal then active handling comes up on the dic. Im not stomping on the brakes and road conditions were dry.
any ideas?
Old Aug 11, 2008 | 01:24 AM
wettvette's Avatar
wettvette
anyone?
Old Aug 11, 2008 | 09:45 AM
Independent1's Avatar
Independent1
St. Jude Donor '08
The shudder is from your ABS engaging. The shudder is the pulsating of the brakes pistons by the ABS.
What size tires do you have on your car?
Old Aug 11, 2008 | 04:01 PM
wettvette's Avatar
wettvette
the brakes were not applied hard enough for the abs to work, and the road was not slippery. its deffinatlely out of character
standard size tyres on the front and 295 35 18 on the back, had them on for 18 months, problem started about 2 weeks ago.
Old Aug 11, 2008 | 04:29 PM
BlackZ06's Avatar
BlackZ06
Did it feel like the car was being pulled to one side as the brake pedal shuddered ????
It sounds to me like one of the sensors used by the Active Handling system is getting flakey.
Have you checked to see if any DTC are set ???
If, for example, as you brake the Steering Wheel Position Sensor (SWPS) erroneously tells the car that you turned the steering wheel (even though you didn't) the AH will try to turn the car in the direction the SWPS says you turned the wheel.
The other sensors used by the AH system are a yaw sensor, a lateral accelerometer, and the wheel speed sensors.
You can most likely eliminate the whell speed sensors as they are also used by the ABS and Traction Control systems .... so if those sensors were failing all 3 systems would have problems.
Again, check the DTC and let's see if the EBCM has spotted a problem yet ..... then we'll go from there.
Old Aug 12, 2008 | 10:29 AM
Independent1
St. Jude Donor '08
^^If you are correct, OP could try turning off AH and see if problem goes away.
Definitely a good idea to check for codes.
Old Aug 12, 2008 | 10:46 AM
Bluefire's Avatar
Bluefire
This is great advice. My car is doing the same thing. The codes I am getting are C1287 and C1288. In my case it is the SWPS causing it. ABS and AH apply the brakes at different rates. When ABS applies the brakes it will feel like the brake pedal is being pumped. When AH is applied the pedal will feel like it attached to a vibrator. AH applies the brakes at twice the frequency that ABS does.
Old Aug 16, 2008 | 05:41 AM
wettvette's Avatar
wettvette
yep mine is a 1287 also. it almost feels like there is fine gravel between the disc and pads (i know its not).So what do i do now?
To a shudder
