Any deeper A4 trans pans for C5's?
Old Jan 1, 2002 | 01:20 AM
GTP's Avatar
GTP
Default Any deeper A4 trans pans for C5's?
Does anyone know of a company selling deeper transmission oil pans for the C5's? I know not just any pan will due since the A4 does'nt have a dip stick but rather the inspection port bolt. If not maybe its possible to buy a regular 4L60-E pan and measure down the correct distance and professionally drill and weld a hung for the bolt.
Thanks,
Aaron Lephart
Old Jan 1, 2002 | 12:13 PM
carpe dm's Avatar
carpe dm
Default Re: Any deeper A4 trans pans for C5's? (GTP)
I thought about a deeper, finned pan to aid in cooling, but have not found one. I also worry about ground clearance on a lower pan. I'm sure you could put in a drain plug if that is all you want. I would rather just change the filter each time I change the fluid, so I would leave the stock pan.
Kenny94945's Avatar
Kenny94945
Great question Aaron.
I do know that there are two different stock pans from my filter buying experiences...a deep and a shallow.
I too would also like to be able to drain the oil.
Any one know the cost of a deep pan off hand and if installing a drain bolt is possible?
Also a very healthy and happy year 202 (202 vs Z06? LOL).
Kenny
Old Jan 2, 2002 | 01:27 AM
ZAP's Avatar
ZAP
Default Re: Any deeper A4 trans pans for C5's? (Kenny94945)
B&M sells a drain plug kit for MSRP of $6.95. You can mail order thru Jeg's :cheers:
To Any deeper A4 trans pans for C5's?
