Brake fluid pressure sensor part number?
Old Aug 10, 2008 | 10:46 PM
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
Default Brake fluid pressure sensor part number?
Does anyone know the part number for this part. Im getting the C1296 code that never goes away.
Old Aug 10, 2008 | 11:38 PM
byronhunter's Avatar
byronhunter
Default Sensor
It's on the driver's side (end) of the Brake Pressure Modulator Valve. (BPMV) Sorry, don't know Pt #.
Old Aug 11, 2008 | 08:15 AM
BlackZ06's Avatar
BlackZ06
Default What year ??
Helps if your profile showed what year your car is .... many parts vary by model year.
Old Aug 11, 2008 | 09:01 AM
Corvette-Chris
St. Jude Donor '08
Old Aug 11, 2008 | 05:13 PM
BlackZ06's Avatar
BlackZ06
Originally Posted by Corvette-Chris
2002
Weird .....
I assume you're trying to fix something like a C1296 ....
The Service Manual describes how to replace the sensor ... it is mounted in the BPMV ....
But the parts manual I have indicates that there is no individual part number for the sensor .... you have to buy a whole new BPMV .....
All I can sugggest is calling a parts dealer and see if they can get a part number for the part ..... .....
Only GM could put in a service procedure for a part you can't buy ....
Old Aug 11, 2008 | 07:24 PM
Corvette-Chris
St. Jude Donor '08
Originally Posted by BlackZ06
Weird .....
Yeah it is the C1296. Ive already tried calling my dealer and they want to sell me the BPMV for $900
Old Aug 11, 2008 | 07:43 PM
BlackZ06's Avatar
BlackZ06
Try contacting these two vendors and see if either one can locate the part number ...
http://www.gmpartshouse.com
http://www.gmpartsdirect.com
Also contact this guy, he may be able to repair it for you for less than the $900.00 dealer quote ....
http://www.absfixer.com
But, to be fair to your dealer ... the GM parts manual does not list a part number for the sensor ... possibly a GM authorized parts seller can locate the number using a computerized search, rather than the older "paper" parts books.
Good luck,
Old Jun 18, 2009 | 07:44 PM
87 Ragtop's Avatar
87 Ragtop
CI 3-4-5-6-7-8-9-10-11 Vet
CI X Blind Auto-X Champ
Old post I know, but exact problem I have. I can go a whole day without throwing this code, or hit a small bump and it kicks off the active handling. Was this sensor ever found as a seperate part, or is it the whole thing. I sure would hate to throw 900 at a part just to find it wasn't the problem.
Old Jun 19, 2009 | 10:18 PM
Gene Culley's Avatar
Gene Culley
Premium Supporting Vendor
I'd be happy to check it out for you, but it doesn't sound good!
Old Feb 20, 2010 | 04:38 PM
Corvette-Chris
St. Jude Donor '08
Im still wanting to find just the sensor part number. Ive read where members have purchased sensors but no GM dealer wants to sell them alone. Its just stupid to have a sensor that can clearly be removed and changed in an hour and not sell it individually.
If you can help in any way Gene, I sure would appreciate it
To Brake fluid pressure sensor part number?
