4L60E parts interchangeable?
Old Aug 11, 2008 | 11:26 PM
396375's Avatar
396375
St. Jude Donor '08-'09
Default 4L60E parts interchangeable?
My 4L60E in my 2000 C5 needs a rebuild.I have found a couple of 4L60Es that are rebuilt but came out of a truck and a Camaro.Are the parts interchangeable so that I could just have everything switched over to my case?Any special years/vehicles that will not work?
Thanks,
Old Aug 12, 2008 | 12:01 AM
C5Natie's Avatar
C5Natie
Your vette has a 4L65E. It has a stronger planetary gear (5 points) and extra clutches in the 3-4 shift compared to a 4L60E.
Old Aug 12, 2008 | 07:46 AM
BlackZ06's Avatar
BlackZ06
Unless you know something about the OP's car that the rest of us don't .... he has a 4L60-E (RPO M30) ... the 4L65-E was only factory installed for the 2005 C6 Corvette. Starting with the 2006 the automatic became the 6L80-E (paddle shift 6 speed - RPO MYC).
As far as using parts from a truck/Camaro 4L60 ... hard to say ... the truck version may have (if it was a 4 wheel drive) a different output shaft, for example. Many of the internal parts are the same .... but the external parts are often different. One thing for sure .... 1997 is kind of a cut-off .... the 4L60 was "upgraded" for most vehicles that year .... so if you are looking at an older tranny than that, you should probably skip it.
To 4L60E parts interchangeable?
