PCM code po705
Old Aug 13, 2008 | 07:45 AM
aleadfoot's Avatar
aleadfoot
Default PCM code po705
This code is for the A4 trans it has something to do with gear selection? My car sometimes lurches forward upon starting doesn't really move the door locks activate with every shift. This occurred after tranny install. I have checked all the connectors. Is there a shifter/cable adjustment needed? Thanks
Old Aug 13, 2008 | 09:15 AM
BlackZ06's Avatar
BlackZ06
First, it is a P0705 (zero seven zero five) .... if you SEARCH need to search with the correct characters.
Second, it could well be that your shifter cable and/or the PNP switch need adjusting.
Third .... FILL OUT YOUR PROFILE .... it makes it difficult to provide you information that is based on, for example, model year, when you don't provide the information.
Finally, I arbitrarily selected 1999 as your model year ... here's the diagnostic data for the problem on a '99 ....
http://www.gearchatter.com/viewtopic9995.php
Old Aug 13, 2008 | 04:43 PM
aleadfoot's Avatar
aleadfoot
Thank you very much
To PCM code po705
