Check Engine Light - Code P0440
Old Aug 13, 2008 | 12:22 PM
kettemr's Avatar
kettemr
Default Check Engine Light - Code P0440
Check Engine Light came on this morning. I checked codes and the only one is P0440. I researched this a bit and the most logical simple fix is to tighten the gas cap. I did this and cleared the code. If this works, how long until the Check Engine light will reset?
What esle should I consider? Thanks!
Old Aug 13, 2008 | 12:38 PM
Doug@MorosoPerformance's Avatar
0Doug@MorosoPerformance
Former Vendor
It should turn off after three ignition cycles if there are no other problems.
www.moroso.com
Old Aug 13, 2008 | 01:40 PM
kettemr's Avatar
kettemr
Thanks for the reply. What would I check next if it does not turn off?
Old Aug 13, 2008 | 02:07 PM
dougbfresh's Avatar
dougbfresh
You can turn it off via the DIC.
Old Aug 13, 2008 | 03:01 PM
kettemr's Avatar
kettemr
Huh? I can turn off the "Check Engine" light via the DIC? I thought I can only use this to erase trouble codes.
Old Aug 13, 2008 | 09:12 PM
dougbfresh's Avatar
dougbfresh
What do you think turns the light ON??
Old Aug 13, 2008 | 11:39 PM
Former Vendor
Let us know if it does not go off after cycling through the ignition cycles, there are several things it can be.
Old Aug 14, 2008 | 09:47 PM
kettemr's Avatar
kettemr
Problem solved... Thanks guys!
To Check Engine Light - Code P0440
