Sluggish After TAC Module Replaced
Old Aug 13, 2008 | 12:54 PM
Hendoo's Avatar
Hendoo
Cruising
Default Sluggish After TAC Module Replaced
After a mind boggling series of electrical malfucntions and misbehaviors, one of the parts replaced was the TAC Module. Since the new TAC Module was installed, the low end throttle response seems to be sluggish. Before the new module a light tap on the gas would easily break the tires loose, now I really have to load up to get the same response.
Could the TAC Module be the culprit?
Thanks,
Hendoo
Old Aug 13, 2008 | 02:36 PM
jedblanks's Avatar
jedblanks
I'm sure you did, but I would reset the computer by unplugging the battery after a change like that.
If you did, it might be sluggish while relearning.
If you did not, then it might need to relearn.
Old Aug 13, 2008 | 03:47 PM
Hendoo's Avatar
Hendoo
Cruising
I have not disconnected the battery since the module was put in, it was done by a dealer, I assume that they would have disconnected it while doing the install but...
I'll disconnect and see what I get.
Thanks.
To Sluggish After TAC Module Replaced
