Which Oil for break in??
Hope the break in goes well.
Eric D
Unless the builder specifies something else and then only for warranty purposes,,otherwise go with M1. I think I'd do 500 on the first fill,,oil and filter and good to go IMO!!
I think some don't realize FORGED pistons have different wall clearances. Engine shop mentioned that
the synthetic was too slick for good break in because of this. They put VR valvoline in for 15 min, then changed it
again. Now I've got about 800 or so miles. Engine has used about 1 qt. It must be sealing though as it has over 500rwhp. In case I didn't mention JE FORGED PISTONS and LS2 BLOCK.
You are the 2nd person I've talked to that mentioned 20-50 Rotella.
I wonder if there is any reason to use regular Synthetic w/this setup?
I do plan to after break in.
On your forged pistons, LS7 and LS9 have them and use Mobil 1 for break in. In fact, if your bores are sized properly for forged pistons, typical they are a looser fit then cast pistons. This is due to greater thermal growth on the forge compared to cast.
Bottom-line, will it hurt a new engine to break it in on non-synthetic oil, most likely not, but to suggest that using synthetic is a bad idea is simply WRONG. It’s your engine and do what you feel is best. But in my opinion, if I just spent a gob of money in rebuild and upgrades, I want the most protection I can get and I would use nothing but what the factory uses, Mobil 1.
Eric D
Eric D
That's my line of thinking for modern "roller" motors. You only really need Rotella on motors like my old BB shark with a flat tappet cam/lifters. I have to keep some of the old dyno oil in it,,and I still add some synthetic to it!!
JC
I run Rotella for 2 oil changes. First change at 1 hour and second change at 500 miles. I then run Valvoline NFS Racing oil for another 2500 miles. Both of these oils contain ZDDP which is an anti-scuff agent that the EPA made the oil companies take out of car oil several years ago.
After 2500 or even 5000 miles, then switch to synthetic.
My $.02
Eric D
"WARNING - NOT FOR ENGINE BREAK IN."
The oil manufacturer THEMSELVES said do not use it for break in. That right there is good enough for me.
Eric D
The bearing clearances on a built motor are typically larger because it will allow more oil to run in between the bearing surface and crank. This is because the motors are pushed harder and the extra clearances help keep the bearing surfaces from binding. Yes a non-synthetic should be used for break-in as the cross hatch is typically a bit coarser on an aftermarket prepped block than an oem one. What seats and ultimatley 'burnishes' the rings for a good seal are the pressures in the cylinder while running. I took the advice of a very well rspected engine builder. You only get about 25-50 miles of good crosshatch to seat with, so you best get the best seal possible in that time. Otherwise you may have to tear it down and rehone it. Here is a good read on the subject: Break in theory.
