Code P0358
Old Aug 14, 2008 | 02:25 PM
keekster's Avatar
keekster
Default Code P0358
Anyone have any experience with this code ??? I have intermiitant starting issues maybe related?
Old Aug 14, 2008 | 03:59 PM
lucky131969's Avatar
lucky131969
DTC P0358 Ignition Coil 8 Control Circuit
Circuit Description
The ignition system on this engine uses an individual ignition coil/module for each cylinder. The PCM controls the ignition system operation. The PCM controls each coil using one of eight Ignition Control (IC) circuits. The PCM commands the IC circuit low when a spark event is requested. This causes the IC module to energize the ignition coil to create a spark at the spark plug. Each ignition coil/module has the following circuits:
A power feed
A ground circuit
An ignition control (IC) circuit
A reference low circuit
Sequencing and timing are PCM controlled. This DTC sets when the IC circuit is out of range.
Conditions for Running the DTC
The engine is operating.
Conditions for Setting the DTC
The PCM detects the ignition control circuit is grounded, open or shorted to a voltage.
Conditions met for less than 1.0 second.
Old Aug 14, 2008 | 07:32 PM
keekster's Avatar
keekster
Thanks Lucky....Any thoughts on what i should check to fix...Maybe bad coil ??
Old Aug 14, 2008 | 07:34 PM
patton's Avatar
patton
St. Jude Donor '09
you could swap with the coil next to it and see if code changes
Old Aug 14, 2008 | 10:38 PM
keekster's Avatar
keekster
Default Good Idea
I'll try that..The code is very intermitent...
Old Aug 14, 2008 | 10:41 PM
lucky131969
Good approach. Also, before you take anything apart, inpect the wiring to the coil and associated harness for chaffing or any damage.
Old Oct 31, 2008 | 01:33 PM
keekster's Avatar
keekster
Hi all swapped the coil code stayed on #8, inspected wireing seemed ok. Any other thoughts?
Old Nov 3, 2008 | 03:43 PM
keekster's Avatar
keekster
Replaced plugs and wires no change
To Code P0358
