97 Electonic Gremlins
Old Aug 15, 2008 | 07:27 AM
LS12NV's Avatar
LS12NV
Default 97 Electonic Gremlins
Hoping someone can help me out. I have a 97 automatic, 402 c.i. motor, F1A supercharger + all the usual mods. The car has an idling problem whereby it revs up and down all on its own. When you press the brake or put it in drive, it stalls. In addition, the boost-a-pump that was recently installed works intermittently. We thought it was a defecive unit, so we switched it out for a new one. Same issue after the swap. We've gone so far as to replace the PCM and BCM. I don't know what to do next!
Has anyone had severe electonic problems with their 97???
Thanks,
LS12NV
Old Aug 15, 2008 | 08:08 AM
Mark C5's Avatar
Mark C5
St. Jude Donor '08-'09-'10
I'd start by reading Bill Curlee's sticky on electrical info at the top of this forum
Old Aug 15, 2008 | 09:15 AM
dougbfresh's Avatar
dougbfresh
Sounds like a vacuum leak to me.
Old Aug 15, 2008 | 09:24 AM
lucky131969's Avatar
lucky131969
Thanks,
LS12NV
1) Check all air intake connections for looseness, anything that would precipitate a leak. (especially around the MAF and TB)
2) Check all vacuum hoses ( since you are FI, do you have a boost gauge that displays vacuum/pressure? if so how much vacuum at idle?)
3) Check fuel pressure at the rail
4) If you have access to software, monitor the sensors for correct readings....i.e. MAF, IAT, MAP, etc.
Not knowing how the BAP is wired , it's hard to be exact. Typically, the BAP receives power directly from the alternator in some way(through direct wire or with a aftermarket harness). If the pump stops working, it is either losing 12 volts, or ground...typically through a relay. Sounds like you are going to have to use a multimeter to check out the wiring and physically shake it down to find the problem.
Old Aug 15, 2008 | 09:42 AM
euro@EFIAlchemy.com's Avatar
0euro@EFIAlchemy.com
Former Vendor
Quite honestly, it sounds like a desired airflow problem, which is in the tune
Old Aug 15, 2008 | 01:35 PM
LS12NV's Avatar
LS12NV
I just read it this morning, thanks. It's definitely going to be where I start...
LS12NV
Old Aug 15, 2008 | 01:37 PM
LS12NV's Avatar
LS12NV
Car was re-tuned earlier this year, and it was running fine. This issue is fairly new.
Old Aug 15, 2008 | 01:40 PM
BlackZ06's Avatar
BlackZ06
I'd follow Lucky131969's advice above .... sure sounds like you have unmetered air or a vacumn leak. That's where I'd start.
Old Aug 15, 2008 | 01:41 PM
LS12NV's Avatar
LS12NV
I believe my tuner checked the vacuum at idle. Only 9 lbs. I believe it should be around 14 lbs.
The way the wiring for the BAP was explained to me is as follows: the wiring/plug that originally goes to fuel pump is plugged into BAP. The BAP is then connected to the fuel pump.
Thanks for the other suggestions. I will look into them.
LS12NV
Old Aug 15, 2008 | 03:02 PM
jedblanks's Avatar
jedblanks
Could also be exhaust leak near o2 sensor, basically has a similar affect of unmetered air (vacuum leak). Screws with the o2 readings.
Old Aug 15, 2008 | 03:30 PM
lucky131969
LS12NV
Sounds like you have a couple of different problems. 9 in.-Hg of vacuum is pretty low. For a benchmark, my setup pulls 23 in.-Hg(stock cam). Not knowing what type of cam you have, it will vary, but 9 in.-Hg still is on the low side.
So the question remains: do you have a split vacuum/boost gauge? If so, you can monitor this yourself.
Old Aug 15, 2008 | 03:43 PM
Former Vendor
Also, if the boost a pump was recently installed, is it set to give higher then stock fuel pressure at idle? This will cause the fueling in the tune to change and it would need to be re-adjusted to compensate for the added pressure.
Old Aug 18, 2008 | 07:48 AM
LS12NV's Avatar
LS12NV
Thanks for all the great suggestions. I'm looking into some of them and will keep you posted...
LS12NV
Old Aug 18, 2008 | 07:54 AM
Pwrtrip75's Avatar
Pwrtrip75
My turbo setup did the same thing till I dialed in the AFR.
Old Aug 26, 2008 | 05:01 PM
Arun@ChampionMotors's Avatar
0Arun@ChampionMotors
Former Vendor
The problem with the idle is the severe blow by. The car smokes like a choo-choo train at idle. The motor was built at a shop with less then stellar rep and when some boost was added it did not like it. When we got the car it only made 500+ rwhp-very low for a 402 with a P1, and very far off from the 600 it supposedly made at another shop. The build was so bad that the crank was not even pinned-who does that?
The electrical gremlins are just that-but it's so hard to pinpoint as whoever did the wiring did not follow a systematic approach to it.
It's really too bad.
To 97 Electonic Gremlins
