Rim fit Qs.
Old Aug 15, 2008 | 02:11 PM
i2oyal i2ed's Avatar
i2oyal i2ed
Default Rim fit Qs.
Will 17"s fit on the back of a 2004 Z06? Thanks!
Old Aug 15, 2008 | 02:45 PM
fdxpilot's Avatar
fdxpilot
Originally Posted by 8VETTE7
Even if they would fit, don't do it. The rear tire diameter MUST be larger than the front tire diameter or you WILL experience Traction Control issues. The car was designed with the rear tires larger and sensors think the car requires the assistance of the Traction Control when the rear tires are turning faster than the front.
Except the computers don't care what his wheel diameter is, as long as he gets tires that are approximately stock diameter or larger (26.1 or so for a Z06.) If so, go ahead and use 17" rims. I assume it is to use a larger selection of drag radials.
