Home Diagnostic Scanner
Old Jan 2, 2002 | 09:33 AM
7thgeneration's Avatar
7thgeneration
Default Home Diagnostic Scanner
Does anyone know which scanner out there would be suitible for home use ? I have a 94 Grand Am and a 2002 Corvette Coupe and was wondering which company and model would be the one to use. I would assume that one with software that could be updated would be the most useful. Thanks Nick :seeya
Old Jan 2, 2002 | 12:37 PM
99HT's Avatar
99HT
Default Re: Home Diagnostic Scanner (5thgeneration)
You will need two different scanners. For cars 1995 or older, there is no set standard. Most GM vehicles of the early 90's used the ALDL bus. You can do a search for this bus on Gran Am web sites or LS1.com.
1996 was the first year for OBDII. Each car company uses a different OBDII interface. Their are at least 3 different ones.
For your 2001 you can go to http://www.obd-2.com or http://www.obdii.com for the lowest cost GM scanners.
Old Jan 2, 2002 | 09:50 PM
geekracer's Avatar
geekracer
You might check out http://www.autotap.com for more info :)
Old Jan 2, 2002 | 10:01 PM
JIM50's Avatar
JIM50
I USE A SNAP-ON SCANNER,VERY USEFUL AND UP GRADES ARE DONE ONCE A YEAR. :cheers:
Old Jan 2, 2002 | 10:30 PM
RadarBlue's Avatar
RadarBlue
Default Re: Home Diagnostic Scanner (JIM50)
I use an Actron. I comes with an OBD-II cartridge and I got a cartridge for pre-96 GM. Works well.
John
Old Jan 3, 2002 | 08:56 PM
ersatz928's Avatar
ersatz928
Default Re: Home Diagnostic Scanner (RadarBlue)
JC Whitney has a generic OBDII scanner for $179 that will work on any 1996 or newer vehicle. I think the brand is Equis.
Old Jan 4, 2002 | 10:42 AM
99HT's Avatar
99HT
It really depends on what you want to do with the scanner. If you want to monitor a lot of stuff, then you will need a PC based scanner. A simple hand held one may not do everything you may want.
Old Jan 4, 2002 | 12:14 PM
Just4Grins's Avatar
Just4Grins
Default Re: Home Diagnostic Scanner (99HT)
One factor: many scanners (X-Ray among them) can scan both OBDII and older vehicles. Most of the home scanners will scan ECM readings only (engine stuff), and will not scan transmission readings. This can be important if you have an automatic with a sensor problems (pressure or shaft speed). Not an issue on my 6 speed couple, but has been an issue on our Suburban with electrically controlled shift points.
To Home Diagnostic Scanner
