Can Baer Eradispeed Rotors be Turned??
Old Aug 17, 2008 | 04:16 PM
JKLNHDE's Avatar
JKLNHDE
Default Can Baer Eradispeed Rotors be Turned??
Need to replace the pads on my 02 Z06 soon and have been noticing a very slight feel in the peddle that is probably slight warpage of my Baer Eradispeed rotors (with stock calipers and pads). If that is in fact the issue, can these rotors be turned to true them up again?
Old Aug 17, 2008 | 06:08 PM
9T3JIM's Avatar
9T3JIM
Yes they can, I just had mine done at the local NAPA which also has a machine shop. The machinist really took his time because the slots and holes can damage the cutting bit. After I got them back I put a coat of clear over the unswept area to keep them from rusting.
