Long Tube troubles
Old Aug 17, 2008 | 02:35 PM
SargeZ06's Avatar
SargeZ06
Default Long Tube troubles
After installing my LG Streets I started up the car and I have no coolant temp reading. It says "Coolant temp. xxx".
My fans start running immediately.
Any ideas?
Thanks,
Steve
Old Aug 17, 2008 | 02:36 PM
hotwheels57's Avatar
hotwheels57
Isn't there a sensor in the drivers side cylinder head that is typically removed for installation of headers?
Maybe it wasn't reconnected or was damaged during the R&R?
Old Aug 17, 2008 | 03:04 PM
zeevette's Avatar
zeevette
Very front of driver's side head. #1 cyl. It's kind of fragile, and if bumped during install, could be broken. Take care when removing...do when engine is cool. Very easy to fix. OTOH, could just be unplugged.
Old Aug 17, 2008 | 03:08 PM
Last C5's Avatar
Last C5
Yup, I smashed mine and had to replace it putting in my long tubes.
Old Aug 17, 2008 | 03:25 PM
slothy's Avatar
slothy
ya hopefully u just unplugged it and didnt break it, its right behind the alt bracket above the front spark plug
Old Aug 17, 2008 | 07:18 PM
SargeZ06's Avatar
SargeZ06
Thanks guys that was it. Just came unplugged whe I removed the alternator.
Deleted my CATs from the tune so now I'm set. Sounds bad-****...
Old Aug 17, 2008 | 07:31 PM
vettenuts's Avatar
vettenuts
I pull the plug and slip a socket over it when working on headers, helps protect it.
To Long Tube troubles
