Average alternator life?
Old Aug 17, 2008 | 09:17 PM
JBACE's Avatar
JBACE
Default Average alternator life?
How long do C5 alternators typically last before needing a rebuild or replacement?
Mine is the original...9 yrs old with 50k miles. Should I be concerned?
Old Aug 17, 2008 | 09:39 PM
Oldvetter's Avatar
Oldvetter
Impossible to guess. Mine is original, 10+ years old and 114,000+ miles.
One thing, it pays to get them rebuilt (re-wound locally). They have data interface, are made in France, and are expensive. Don't get an "auto parts" replacement, it will throw codes.
Old Aug 21, 2008 | 09:41 PM
JBACE's Avatar
JBACE
Thanks for the response Oldvetter!
Old Aug 22, 2008 | 02:54 AM
thetaxman's Avatar
thetaxman
160k miles + on mine
Old Aug 22, 2008 | 03:18 AM
LoneStarFRC's Avatar
LoneStarFRC
No, you shouldn't. Mine has 149K and is still working fine. Usually when they DO fail it is not because of the windings, but rather the bearing(s) or the internal voltage regulator, etc.
I agree with being cautious about sourcing a replacement and would highly recommend either a remanufactured Delco (reman BY Delco and sold under a Delco part number) or new. If you chose to have your individual unit remanufactured, stick to a reputable company that will stand behind their work.
HTH
Old Mar 23, 2010 | 02:08 PM
Z0ra6's Avatar
Z0ra6
So a car with only 13K miles (2003) should not have to worry about this? I have my head lamps dimming sometimes, but I'm not sure if it's the underdrive pulleys or a bad battery connection. The battery tight and clean (looking).
I had someone tell me an alternator could go bad just based on age alone, so I didn't know to believe him or not.
Old Mar 23, 2010 | 03:47 PM
dougbfresh's Avatar
dougbfresh
All the GM's I ever had, the alternators went to about 90-100K before they died, usually a diode gives up the ghost.
Old Mar 23, 2010 | 03:55 PM
LoneStarFRC
When I originally posted in this thread in Aug 2008, I had 149K miles on mine.
I now have 161K+ miles. Same alternator.
To Average alternator life?
