Oil Pump Question
Old Aug 17, 2008 | 09:58 PM
donkelso's Avatar
donkelso
Default Oil Pump Question
I installed a cam in my 2000 vert about six months ago and replaced the oil pump at the same time. I followed the procedure for a cam install on LS1 tech and it did not have a step to align the new oil pump on the crank shaft, so I did not clearance the pump housing when I installed it. The engine runs fine and has normal oil pressure, but I am second guessing myself now on whether I should go back in and clearance the pump housing properly. Advice??
Old Aug 17, 2008 | 10:18 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Many people simply bolt them up and go, never looking back and have no issue. I have even talked with a couple of reputable shops that do it. You will be fine I'm sure.
Old Aug 17, 2008 | 10:43 PM
falcon5619's Avatar
falcon5619
Are you referring to the step where you center the pump on the shaft by using some feeler gauges?
Old Aug 17, 2008 | 10:48 PM
vettenuts's Avatar
vettenuts
Sounds like it. Not sure who came up with this method, it is not in the service manual and I still don't understand what it buys you. The center gear self aligns.
I didn't do it on mine and no problems.
Old Aug 17, 2008 | 10:50 PM
falcon5619's Avatar
falcon5619
Good to know. I am getting ready for my cam swap soon.
To Oil Pump Question
