Cam help PLEASE
Old Aug 17, 2008 | 11:47 PM
fst85vtt's Avatar
fst85vtt
Default Cam help PLEASE
I came across a killer deal on heads and cam its a comp cams 54-446-11 i have a stock bottom end 2000 ls1 with prc 2.5 ls6 heads 64cc ls6 intake 6 spd 342s
heres the specs will this cam work??? seems a bit large
rpm range 2400-7200
valve timing.0006
lobe center angle 112
intake centerline 110
duration 281--283
@500 232 234
lift 595 598
lobe lift 0.35 0.352
valve timing lift @ .0006 lift open close
intake 31 btdc 71 atdc
exhuast 76 28
Old Aug 17, 2008 | 11:50 PM
geterdone's Avatar
geterdone
Those are not the specs. Need lift, duration and LSA plus possible degree advanced.
Old Aug 18, 2008 | 12:33 AM
fst85vtt's Avatar
fst85vtt
anyone
Old Aug 18, 2008 | 12:40 AM
BlueRag's Avatar
BlueRag
Based on what you posted, that cam is 232/234 I/E @.050" with an 112LSA and 2' advance ground in. Looks to be an XER lobed cam too. Pretty large street cam by my standards, and I would probably want a little more static compression with that cam by milling the 64cc heads another 0.015-0.020". If you are looking for a choppy cam, you found the right one
Old Aug 18, 2008 | 12:46 AM
fst85vtt's Avatar
fst85vtt
yeah i think i may just shop around for one that better suits me but at least with the springs that are on the heads i im not limited
To Cam help PLEASE
