True HorsePower
Old Aug 18, 2008 | 01:53 PM
jforce's Avatar
jforce
Default True HorsePower
Does anybody know the formula to use to figure out your true horsepower @ the crank if you've got the rearwheel horsepower dyno readout?
Bruce
Old Aug 18, 2008 | 02:30 PM
jpandes's Avatar
jpandes
Don't most people just assume a 15% drivetrain loss and multiply the rwhp by 1.15? That sounds about right...The C6 Z06 dynos at 439ish stock.... 439 * 1.15 = 504.85
Mine: 429rwhp * 1.15 = 493 bhp
Ignore my post above...Apparently, I was wrong.
Old Aug 18, 2008 | 02:37 PM
Bigstik's Avatar
Bigstik
Not quite. The formula for RWHP from BHP (Crank) is BHP*0.85 = RWHP. So to go backwards it is RWHP/0.85 = BHP.
Although 15% loss has been discussed at length and you might get a WHOLE lot of different answers on this, 15% is a good estimate, but the really important thing is how much gets to the road and how well you know how to us it.
Old Aug 18, 2008 | 03:30 PM
Gordy M's Avatar
Gordy M
Chassis dyno's are mostly used for comparison tuning. Dyno the car, make the changes, re-dyno the car and measure the difference to SAE standards. Comparing the amount of drive train/rotating mass loss from one day to another on a chassis dyno can be very misleading. You know every C6Z leaves the factory at 505 hp SAE and if you were to make three dyno pulls and you will see the different hp readings and they more that likely are different from someone else's hp claims. Then you have the different types of dyno's--drum, load bearing, etc....otherwise know as dynojet, mustang, etc.
Bottom line there are some general "rule of thumbs" but non are accurate
Old Aug 18, 2008 | 03:41 PM
ZeeOSix's Avatar
ZeeOSix
The drive train loss does not change unless you change something in the drive train (ie, tires, wheels, gearing, etc).
OP -- read this thread. This question has been beat over and over and over again.
http://forums.corvetteforum.com/show....php?t=2083989
Old Aug 18, 2008 | 03:55 PM
zeevette's Avatar
zeevette
I'd just like to add my opinion, which has recently been changed....I don't have a clue.
Old Aug 18, 2008 | 04:19 PM
jforce's Avatar
jforce
Thanks Guys
Old Aug 18, 2008 | 05:15 PM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
Multiplying by 1.15 and dividing by .85 provides you with 2 different answers. Dividing by .85 is the correct way.
Old Aug 18, 2008 | 06:43 PM
gunnerrun's Avatar
gunnerrun
Default Exactly
Exactly Correct! If in doubt, take .85 times of 500 or 85% of 500 said a bit differently, and then divide the ans 425 by .85 which will equal 500.
Old Aug 18, 2008 | 06:52 PM
jpandes's Avatar
jpandes
Ok, my bad. But wait...If I convert rwhp to bhp by dividing 429 rwhp by .85 I get 504 bhp. WOo-hOo!
Old Aug 18, 2008 | 08:31 PM
C5XTASY's Avatar
C5XTASY
The general rule of thumb is a 15% drivetrain loss for a manual transmission and 20% for am automatic. However, people still use those percentages no matter what the car is putting down at the wheels. That doesn't make a whole lot of sense to me, as I do not believe drivetrain losses will increase in a linear manner with power output. About the only real measure, IMHO, would be to pull the engine and dyno it, and then reinstall it and dyno the car at the wheels. Obviously, no one would want to do that, which, come to think of it, is probably why 15% and 20% are always used.
Ed
Old Aug 18, 2008 | 08:45 PM
ZeeOSix's Avatar
ZeeOSix
So how do you think drive train loss will change with increased engine power output?
Old Aug 19, 2008 | 12:11 AM
motogib1's Avatar
motogib1
I personally believe that drivetrain loss will vary somewhat as power increases. Don't have proof off hand but I'm certain that it can be proven.
Old Aug 19, 2008 | 03:02 AM
bvillezo6's Avatar
bvillezo6
From: Virginia Beach VA...originally Burtonsville, MD
If this turns in to another pissing contest.....:rof l:
Old Aug 19, 2008 | 03:03 AM
ZeeOSix's Avatar
ZeeOSix
I'm with you ... and to be more specific the loss % probably increases slightly as the HP levels go up. As an extremely simple example, the drive train loss % might be 12% at 100 HP, 15% at 400 HP and 18% at 700 HP.
Old Aug 19, 2008 | 09:46 AM
vrybad's Avatar
vrybad
When is that damn ZR1 going to hit the dyno so we can have more info...
Old Aug 19, 2008 | 10:00 AM
C5XTASY's Avatar
C5XTASY
If you had read my reply, that's what I said. I don't believe that drivetrain loss increases in a LINEAR manner. In other words, it may be 15% with a 350hp engine but a different percentage with a motor of greater, or lesser, power. There's just no way to figure it out without dynoing a motor seperately from the car, and then dynoing with the motor in the car. However, personally, I believe that with higher horsepowers, while total drivetrain loss increases, the percentage of drivetrain loss will decrease. In other words, a 700hp motor will have greater drivetrain loss than a 350hp motor, but not twice as much.
Ed
To True HorsePower
Old Aug 19, 2008 | 05:23 PM
ZeeOSix's Avatar
ZeeOSix
Ed
After reading this reply of yours, it's really not what you think I said, as I think the % of drivetrain loss will increase with increased HP levels, not decrease like you theroize.
So you're saying a drivetrain becomes more efficient as the power going into it increases. I don't think so ... why would it magically become more efficient with more stress on it?
Old Aug 19, 2008 | 05:33 PM
AU N EGL's Avatar
AU N EGL
Bruce
Simple
When you exit one corner or the starting line and lay two black streaks down the track into the braking zone, THAT is right amount.
Old Aug 19, 2008 | 05:45 PM
ZeeOSix's Avatar
ZeeOSix
Exactly ... this will give a good date point on the upper end of the HP range. Once the ZR1 dyno HP numbers start coming in, someone could compare 2001 Z06, 2002-2004 Z06, C6 Z06 and ZR1 numbers and determine the percentage of drivetrain loss and if there is a change in the % loss trend with HP levels.
