Injector help
Old Aug 19, 2008 | 08:27 AM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
Default Injector help
I have a friend who has a 1997 all stock Corvette. Within the last year he has blown two fuel injector fuses. What could cause this? Is it a bad injector somewhere or a short in the wiring?
I have a C4 so this is new stuff to me.
Old Aug 19, 2008 | 08:58 AM
KCvetteowner's Avatar
KCvetteowner
I would check the wiring to the injectors, I've read some reports of the insulation on the wiring wearing through near the back of the motor between the head and firewall.
Old Aug 19, 2008 | 09:13 AM
dougbfresh's Avatar
dougbfresh
Good idea, but you need to unplug each injector and measure the resistance, I seem to recall it needs to be 10-14 ohms.
Old Aug 19, 2008 | 09:49 AM
Kubs's Avatar
Kubs
Thanks! I will tell him to look at those and report back to you.
Old Aug 20, 2008 | 01:00 PM
Kubs's Avatar
Kubs
If the injectors do have to be replaced what is the flow rate of a stock C5 injector and how much do they typically run for a set??
Old Aug 20, 2008 | 01:20 PM
FICINJECTORS's Avatar
FICINJECTORS
Supporting Vendor
pm sent
Old Aug 20, 2008 | 02:25 PM
dougbfresh's Avatar
dougbfresh
I send injectors to http://www.cruzinperformance.com/ They do a initial flow test/electrical test, clean them, put in new screens and flow test then putting the results on their website for you to see. Great place.
To Injector help
