Valve spring options
Old Aug 19, 2008 | 11:50 PM
Targa98's Avatar
Targa98
Default Valve spring options
What springs do you guys use with your H/C cars? I have my heads being done right now and we would like to use at LEAST a 400lb. spring. Now, My spring pocket will most likely need to be machined larger and the springs may be taller also. So I was wondering what path you guys have taken with your more serious cams??
Old Aug 20, 2008 | 08:35 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
PRC or Patriot Gold Extreme's good to .660 lift seem to be the most popular. PAC's and Comp Cams 921's are popular as well. You need to pick out your cam and get your springs so the guys at the head shop can set them up properly. The springs should get set up differently for different cams based on your true valve lift.
Old Aug 20, 2008 | 12:15 PM
WKMCD's Avatar
WKMCD
I was running Comp 921's but recently changed to the new PAC 1521's to handle the lift on the new cam. The 1521's are good for .700 lift. I think these are undoubtedly the best springs out there now.
Old Aug 20, 2008 | 01:38 PM
Targa98's Avatar
Targa98
I was looking at the 921's. I definitely prefer Comp products. But I wanted to go a little more high perf. I will be seeing over 7000 rpm so I want to be safe. Is anyone here built N/A seeing 7-8,000 rpm? Curious what valvetrain options you went with.
Old Aug 20, 2008 | 03:15 PM
WKMCD's Avatar
WKMCD
Better than 921's = PAC 1521's for a drop in spring. They are nitrited and will last longer than the 921's.
Old Aug 21, 2008 | 07:38 PM
vettenuts's Avatar
vettenuts
The other thing to watch with a larger diameter spring is contact with the rocker by the retainer. You may need an offset to bring the retainer down but not sure if that will buy enough clearance.
When you say 400#, at what lift are you looking for that value? The PSI 1511ML's are good springs with a stiffness of 384 lb/in.
To Valve spring options
