YET another blinker issue!
Old Aug 20, 2008 | 10:18 PM
at88mph's Avatar
at88mph
From: The artist formally known as NONO5.0 Mobile, Al
Default YET another blinker issue!
Ok, I'm lost! I've tried three bulbs in the front turn signal and can't get the thing to blink regular. (fast blink passenger side front turn signal) I know its not the blubs. The weird thing is when I press the hazard button, it flashes normally....turn off the hazard, it goes back to fast blinking. I know none of the other blubs are out either. Anybody know the fix for this?
Old Aug 20, 2008 | 11:03 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Ive seen this before! Its most likely a bad multifunction switch. Theres a post in the archive on repairing your own switch fror FREE. It goes step by step on how to fix it.
Try that first.
Bill
Old Aug 21, 2008 | 10:55 PM
at88mph's Avatar
at88mph
Try that first.
Bill
Thanks for the reply Bill I think I saw that and I think I'd rather just live with the spastic blinker though
Thanks again
Old Aug 22, 2008 | 12:40 PM
Benpup's Avatar
Benpup
Cruise-In VI Veteran
Check to make sure both of the rears are flashing also. One burnt out in the rear will do the same thing I believe.
Old Aug 23, 2008 | 06:27 AM
paullywalnuts's Avatar
paullywalnuts
Its probably corrosion in the 3 way hazard switch..luckily I still had warranty to fix mine but the switch is around $80 I think...then you have to take the whole console out..looked like a real pain on the link I saw..you may get tired of not having turn signals after a while though.
Old Aug 23, 2008 | 08:52 AM
Mac11's Avatar
Mac11
I had the same problem with a bad ground contact in the socket. I cleaned it up with a little scotchbrite and a pencil eraser.
Old Aug 23, 2008 | 09:39 AM
jedblanks's Avatar
jedblanks
Are you certain you have the right amount and correct brand of blinker fluid?
Old Aug 23, 2008 | 09:55 AM
AMRAAM's Avatar
AMRAAM
I have a rear wiring harness that has been hacked by the previous owner. The lights have been doing different weird things, but right now, only one of the right side rear signals is working and it has the spastic signal.
To YET another blinker issue!
