help- c5 fender flares
Old Aug 21, 2008 | 10:36 PM
turboed's Avatar
turboed
Default help- c5 fender flares
looking for rear flares since i'm mounting oem c6 zo6 wheels,can someone help with some options?
Old Aug 21, 2008 | 11:18 PM
jdmvette's Avatar
jdmvette
Night Owl for life
L5 flares; same wheels as you want.
Old Aug 22, 2008 | 07:19 AM
turboed's Avatar
turboed
i should have been more specific but thanks for the pictures,what i need is contact info on where to get them or other similar ones,i have the same wheels polished,what did you pay for yours?
Old Aug 22, 2008 | 08:00 AM
Z06PSI's Avatar
Z06PSI
St. Jude Donor '17-'18-'19
Search for L5 or Lewis Five motorsports here on the board and you will find what you need.
Old Aug 22, 2008 | 10:18 AM
DavzC5's Avatar
DavzC5
From: Houston, TX www.djmotorsportaccessories.com Specializing in C5 & C6 Accessories. DJ Motorsport Accessories.
St. Jude Donor '08-'09
I got mine from Gulf Coast now EnglandGreen. Paid $840 and $160 shipping. Cost another $900 for fitment paint and install. Then the 4k on wheels & tires.
Old Aug 22, 2008 | 10:33 AM
Drewstein's Avatar
Drewstein
I got mine from WCMC and they look fantastic!
Old Aug 23, 2008 | 03:17 AM
turboed's Avatar
turboed
thanks guys.
Old Aug 23, 2008 | 07:38 AM
AU N EGL's Avatar
AU N EGL
Mine are ACP http://www.corvetteracebodies.com
3/4" wider then stock, so very subtle looking
Old Aug 23, 2008 | 09:57 AM
turboed's Avatar
turboed
i don't see pricing at corvette race bodies.
Old Aug 23, 2008 | 09:59 AM
turboed's Avatar
turboed
[QUOTE=jdmvette;1566806679]L5 flares; same wheels as you want.
did you use spacers?
Old Aug 23, 2008 | 01:12 PM
AU N EGL's Avatar
AU N EGL
under C5 World Challenge body parts
http://www.corvetteracebodies.com/wo...ice%20list.htm
CF= Carbon Fiber FG = Race wt fiber glass
Fender-Rear Left Flared C5/A0009-3/4"W-CF $963.00
Fender-Rear Left Flared C5/A0009-3/4"W-FG $422.00
Fender-Rear Right Flared C5/A0010-3/4"W-CF $963.00
Fender-Rear Right Flared C5/A0010-3/4"W-FG $422.00
Fender-Front Left C5/A0048 -CF $966.00
Fender-Front Right C5/A0048 -CF $966.00
Old Aug 23, 2008 | 01:53 PM
turboed's Avatar
turboed
[QUOTE=AU N EGL;1566821804]under C5 World Challenge body parts
your avatar rocks,what exactly does that symbol mean?i saw it on a c6
Old Aug 23, 2008 | 05:17 PM
AU N EGL's Avatar
AU N EGL
Thanks. That is JAKE. The Symbol of Corvette Racing and means Take No Prisoners.
and I replaced my front corvette flags with Jake. Pic is a close up from my front facia
Old Aug 23, 2008 | 06:32 PM
hattitude's Avatar
hattitude
I don't like the look of the flares without those fender guards (splash guards?), are those from a C6Z06? How hard was it to fit them?
Thanks in advance
Old Aug 23, 2008 | 06:34 PM
RedRiderZR1's Avatar
RedRiderZR1
Do the C5 World Challenge body parts bolt right up. All the pictures I am seeing show a fender that also has a flared rocker as well. I am looking for a flared quarter, but want one that will bolt right up. I have 335s going on the rear. they stick out 3/4 inch. Not looking to go with L5s due to having to use a spacer for them to look right.
Greg
Old Aug 23, 2008 | 08:25 PM
turboed's Avatar
turboed
i just pulled the trigger on the lewis motorsports with the guards and all and had them shipped straight to the bodyshop,who sells the wheel spacers?can't find them at local autoparts.
Old Aug 23, 2008 | 10:18 PM
jdmvette's Avatar
jdmvette
Night Owl for life
yes i use 5/8" spacers.
here's more details to help you decide.
http://forums.corvetteforum.com/show...391&highlight=
To help- c5 fender flares
jdmvette's Avatar
jdmvette
Night Owl for life
Thanks in advance
yes i used OEM c6 z06 parts and modified them.
it is very labor intensive.
Old Aug 23, 2008 | 10:19 PM
jdmvette's Avatar
jdmvette
Night Owl for life
let me know which spacer size you want to go with and i will recommend which ones you should get.
Old Aug 23, 2008 | 10:33 PM
jdmvette's Avatar
jdmvette
Night Owl for life
spacers are needed when using wheels that are made for another car (e.g. OEM C6 Z06 wheels).
if you get a set of aftermarket wheels that are designed to be wider with the correct offsets (such as a 19x13), then you wouldn't need spacers.
i run spacers because the wheels i chose to run are designed for a c6z. if i was running a custom set of CCWs, i would have ordered some that already have the extra clearance built in to the wheel, so no spacer would be necessary.
