Ignition wires
Old Aug 22, 2008 | 10:45 AM
c5Cruiser's Avatar
c5Cruiser
From: Corona CA - "An Armed Society is a Polite Scociety"
Default Ignition wires
I'm changing out the plugs and wires this weekend and I was looking for an opinion on which of the two wires I should go for?
7mm
http://www.westcoastcorvette.com/p-4...ire-set-8.aspx
or the
8.5mm
http://www.westcoastcorvette.com/p-4...res-set-8.aspx
Old Aug 22, 2008 | 10:49 AM
corvettebob1's Avatar
corvettebob1
7mm
or the
8.5mm
Save your money and go with the 7mm set, the MSD wires will only empty your pocket!
Old Aug 22, 2008 | 11:00 AM
lucky131969's Avatar
lucky131969
7mm
or the
8.5mm
Neither.....
How can you go wrong with the GM wires??
12495519 – GMPP red spark plug wire set – 55.20: from GMPartshouse.
Old Aug 22, 2008 | 12:00 PM
c5Cruiser's Avatar
c5Cruiser
Both sets are $69.95 ea.
Old Aug 22, 2008 | 12:01 PM
c5Cruiser's Avatar
c5Cruiser
Originally Posted by lucky131969
Neither.....
$55.20? I'll look into them.
Thanks!
Old Aug 22, 2008 | 07:11 PM
itzza427's Avatar
itzza427
I have the MSDs and so far so good. GM reds are fine pieces as well. To be honest the only reason I used MSDs was I needed something quick as I was getting the car ready for display in the Valvoline Dyno Display at the Mid West Nationals. I only had 2 days and the dealer had to order them in so the neighborhood speed shop could get MSDs the next day. I've heard nothing but good about the GM reds but I've had no trouble with the MSDs!!
Old Aug 22, 2008 | 08:24 PM
c5Cruiser's Avatar
c5Cruiser
I may go MSD also.
Just like your stealership, they have to order them and WCC has the MSD's in stock.
Once I start working on her I just want to finish it and not go back when the parts get in.
Thanks for the info.
To Ignition wires
