PCV Catch Can installation HELP
Old Aug 22, 2008 | 02:00 PM
C3Paul's Avatar
C3Paul
Default PCV Catch Can installation HELP
My Elite Engineering Catch Can just arrived and I need a little installation help.
As my Z06 is 2004 build, Am I right to follow the installation instruction for C6/LS2 Engine?
http://www.eliteengineeringusa.com/i...tructions.html
Thank you
Paul
P.S. Elite customer service is awful. 24 hours to get a reply to a question this day and age is not good.
Old Aug 22, 2008 | 02:13 PM
ZeeOSix's Avatar
ZeeOSix
Thank you
Paul
If you have a C5 then follow the C5 instructions.
http://eliteengineeringusa.com/Insta...uctions_CC.pdf
Old Aug 22, 2008 | 02:20 PM
C3Paul's Avatar
C3Paul
The C5 instruction says that 2004 C5 and C6/LS2 are the same!?
Plus C6/LS2 has lots of pictures eazy to follow instruction!
Old Aug 22, 2008 | 06:11 PM
ZeeOSix's Avatar
ZeeOSix
I don't see where the C5 instructions say it also applies to the C6. That's why there is a separate instruction for the C6.
Use the C5 instructions and look at the detailed sketches.
What part don't you understand?
Old Aug 22, 2008 | 06:25 PM
LoneStarFRC's Avatar
LoneStarFRC
I think the 2004 C5s don't have a conventional external PCV valve but instead have an orifice in the tube coming out of the valley cover like the LS2s, etc.
HTH
Old Aug 22, 2008 | 06:33 PM
ZeeOSix's Avatar
ZeeOSix
HTH
Yes, that is certainly true. The instructions for the C5 covers that new PCV configuration too, and was also written to cover the LS2 setups in GTOs, etc.
Old Aug 22, 2008 | 10:52 PM
ChipN's Avatar
ChipN
Default This should help
I've got an '04 C5 and was a little confused by the directions. Turns out to be pretty simple. This should help.
http://www.comp-soln.com/misc/catch_can.jpg
Chip
Old Aug 23, 2008 | 04:36 AM
C3Paul's Avatar
C3Paul
Chip
That's the one
Thank you
Old Aug 23, 2008 | 04:42 AM
C3Paul's Avatar
C3Paul
This is where it says
2004+ LS1, LS6 and LS2
• Carefully remove the short rubber hose located between the metal fitting located on the
RH front corner of the valley cover and the front RH side of the intake manifold.
Old Aug 23, 2008 | 08:41 AM
LoneStarFRC
The basic routing of the hoses will be the same either with OR without an external pcv valve.
To PCV Catch Can installation HELP
