Headlights squeak when turned on/off. WTF???
Old Jan 3, 2002 | 12:09 AM
99 Corvette's Avatar
99 Corvette
Default Headlights squeak when turned on/off. WTF???
Does anyone know what would cause this :confused:
Jerry
Old Jan 3, 2002 | 04:43 AM
Blackjetvette97's Avatar
Blackjetvette97
Default Re: Headlights squeak when turned on/off. WTF??? (99 Corvette)
99 Corvette,
I think there are some pivot points on the arms of the light raising/lowering assembly which cause the squeeking. Some WD-40 should take care of that. Have someone turn the lights on and off while you are right down there listening to where it is coming from, then just a quick shot of the WD.
Steve
Old Jan 3, 2002 | 12:15 PM
Bluewasp's Avatar
Bluewasp
NoVa Events Coordinator
St. Jude Donor '14
Jerry
Mine started to squeak when the weather got colder. I haven't messed with the headlights yet....
WD-40 should take care of it.
Old Jan 3, 2002 | 12:16 PM
JT-C6's Avatar
JT-C6
Cruise-In IV Veteran
St. Jude Donor '03-'06-'08-'10-'11
Default Re: Headlights squeak when turned on/off. WTF??? (Bluewasp)
It's funny you guys mention this, I just noticed this with the cold weather now too.
Old Jan 3, 2002 | 01:09 PM
Superj's Avatar
Superj
Default Re: Headlights squeak when turned on/off. WTF??? (JT-C5)
Me too. I'll test the WD-40 trick.
Old Jan 3, 2002 | 01:12 PM
Cam69ss's Avatar
Cam69ss
Yep me too, my pass. side squeaked. Doesn't sound like a $50,000 car with 7300 miles to me?
WD-40 will do the trick
Old Jan 3, 2002 | 01:20 PM
Allthrottleandsomebottle's Avatar
Virginia Events Coordinator
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
Been there, done that!
Do the rear pivot arm joint on both lights with WD-40.
I also did the front side ones as well.
Use a flash light from the engine compartment side, you will see them.
You do not need to take off the black plastic light guard.
Works like a champ.
Old Jan 3, 2002 | 03:50 PM
carpe dm's Avatar
carpe dm
WD-40 is great, but I have found Valvoline Synthetic spray or Amsoil's Metal Protector to be better on this sort of thing. :yesnod: :)
Old Jan 3, 2002 | 06:02 PM
2thDr's Avatar
2thDr
Default Re: Headlights squeak when turned on/off. WTF??? (carpe dm)
Did you check for a mouse?
Old Jan 3, 2002 | 06:45 PM
rcwalters's Avatar
rcwalters
Default Re: Headlights squeak when turned on/off. WTF??? (2thDr)
Mine is squeaking too now.
Old Jan 4, 2002 | 02:58 AM
pkmoose's Avatar
pkmoose
Cruise-In III Veteran
Default Re: Headlights squeak when turned on/off. WTF??? (rcwalters)
Mine squeak, wtf, it sounds like a pos when the headlights go down, I will try the WD-40 this weekend.
Old Jan 5, 2002 | 08:01 AM
EHS's Avatar
EHS
Default Re: Headlights squeak when turned on/off. WTF??? (pkmoose)
Silicone spray works well too. No need to repeat as often as oil.
Old Jan 5, 2002 | 10:09 AM
levrac68's Avatar
levrac68
Default Re: Headlights squeak when turned on/off. WTF??? (EHS)
My thoughts exactly. I had a squeek under my car where the springs held the exhaust and it came back time and again with the 40. I sprayed Silcone once 6 months ago and nothing since.
To Headlights squeak when turned on/off. WTF???
