LED tail light
Old Aug 23, 2008 | 08:44 AM
makn hp's Avatar
makn hp
Default LED tail light
I just bought these LED tail lights when I put them in they started flashing vary fast, can some tell me what I'm missing here. thanks
Old Aug 23, 2008 | 08:51 AM
LoneStarFRC's Avatar
LoneStarFRC
A flasher bypass wire harness. Give jdmvette a shout, he can help.
Old Aug 23, 2008 | 05:43 PM
BanditDude's Avatar
BanditDude
Was the car running? Mine often flash fast when the car is off, but have never done so while driving.
Old Aug 23, 2008 | 09:05 PM
ToplessBlonde's Avatar
ToplessBlonde
It needs a resistor.
I have the hyperflash on the passenger side, but not the driver. Go figure!
Old Aug 23, 2008 | 09:36 PM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
contact Richard at Corvette Enhancements for the harness........
Old Aug 23, 2008 | 10:06 PM
jdmvette's Avatar
jdmvette
Night Owl for life
did you buy a complete tail light housing replacement or just some LED bulbs?
Old Aug 23, 2008 | 10:07 PM
LoneStarFRC
He doesn't need a resistor. The flasher bypass harness solves the problem of LED "quick flash" without any resistors.
Old Aug 23, 2008 | 10:50 PM
jdmvette's Avatar
jdmvette
Night Owl for life
resistors =
flasher harness =
Old Aug 24, 2008 | 12:36 AM
D C's Avatar
D C
USMC (retired)
Originally Posted by jdmvette
resistors =
flasher harness =
Old Aug 24, 2008 | 12:45 AM
cdn ws6's Avatar
cdn ws6
I have Richards flasher bypass harness and no issues with hyperflash for me!
Old Aug 24, 2008 | 08:57 AM
VET IT B's Avatar
VET IT B
"Ditto" Richard is the man.
Old Aug 24, 2008 | 07:10 PM
Bville-Bud's Avatar
Bville-Bud
St. Jude Donor '05-'06-'07-'08
I've got the same problem; I ordered the module from Richard and will put it on this week. Those who have done it - any issues with CLB module and this module working together?
Old Aug 24, 2008 | 08:26 PM
cdn ws6's Avatar
cdn ws6
Nope, both work fine for me!
Old Aug 24, 2008 | 08:41 PM
mtndv8's Avatar
mtndv8
Default do it.
Nope.
Works as advertised! 20 minutes max to install.
Richard's the man.
Aloha
Michael
Old Aug 24, 2008 | 09:21 PM
LoneStarFRC
Firstly, this bypass harness is NOT a "module". It is merely a type of "piggyback" circuit that allows the turn signal lights to have their own separate flasher from the one normally used by the signal lights. It uses a separate electronic variable load flasher that the signal lights will use, once installed. It does not involve cutting or splicing, etc. It is a true "pnp" and can be changed back to stock at any time and has nothing whatsoever to do with, nor will it interfere with, the CLB circuitry.
HTH
Old Aug 25, 2008 | 11:07 AM
Camjamsdad's Avatar
Camjamsdad
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
And once you install Richards harness then go ahead and enjoy front LED turn signals as well. Search for switchbacks. Wait I think Richard started selling them as well???
Old Sep 5, 2008 | 03:54 PM
Bville-Bud's Avatar
Bville-Bud
I've been way too busy lately, but finally installed Richards harness. Works perfect!!
To LED tail light
