Change shift points
Old Aug 24, 2008 | 11:38 AM
Mabolzich's Avatar
Mabolzich
Default Change shift points
I was wondering how you can change the shift points on my 1998 C5
I've had it for 3 months now and I'm trying to get it to do 0 to 60 in 5.1 seconds like it says in the ads. I started out with a 6.23 time and after fiddling around with it (plugs, wires, etc.) I got it down to 5.41 seconds. I have held in first, but I'd rather have the computer do it. I think I could break that time if I could stay in first up to 60.. Now it shifts at 54 mph. Is there a tuner available that will work on a 98 and grant my wish. I might add that this is a five footer, a Calif. car, very welll maintained, dosen't leak anything, has over 120,000 miles on it, and runs like crazy.
Old Aug 24, 2008 | 03:45 PM
OhioC5's Avatar
OhioC5
I could do it if you were in Ohio. Im not a "tuner" but have the software and its pretty easy.
Old Aug 24, 2008 | 08:51 PM
wildbadbill's Avatar
wildbadbill
I just got Diablo Predator and it can do that......
Also,you can change your max rpm and host of other things....
Old Aug 25, 2008 | 02:33 AM
BlackZ06's Avatar
BlackZ06
You will need to raise your redline also .... to hit 60 with a 2.73 rearend you'll need to rev the engine to about 6500 rpm.
To Change shift points
