What do these codes mean?
Old Aug 24, 2008 | 03:56 PM
cheez22's Avatar
cheez22
Default What do these codes mean?
I just removed my EBCM and I now have the following codes:
Tach signal malfunction
Battery #1 and #2 circuit
Mirror position sensor signal circuit
Could these have anything to do with the removal? Or is this something entirely different? I know I probably should have checked the codes before removing unit.
Thanks.
Old Aug 24, 2008 | 04:38 PM
ZeeOSix's Avatar
ZeeOSix
Sure doesn't seem they would be related. I'd clear them out and see if they return. Could have been a glitch.
Old Aug 24, 2008 | 05:51 PM
BlackZ06's Avatar
BlackZ06
Also, you should post the ENTIRE code ... not the text .... the Service Manual is organized by the codes (P1234H for example) .... and posting ..... Battery1 means nothing, there are dozens of devices that could issue that partial message.
Old Aug 24, 2008 | 08:36 PM
cheez22's Avatar
cheez22
Oh, sorry.
AO LDCM B2282H, B2284H, B2262H, B2264H, U1064H
AI RDCM B2283H, B2285H, B2263H, B2265H, U1064H
I know its a lot of codes. Hopefully its just a glitch. I never had any problems before, except for the EBCM. But, we're taking care of that problem!
Old Aug 24, 2008 | 08:44 PM
renegad44's Avatar
renegad44
From: This is not a Song, It's an Outburst: Or, The Establishment Blues; Sixto Diaz Rodriguez
Here's a couple of listings of codes....but someone else more tech savvy would probably have to step in to say for sure what problem you're having.
http://www.stengel.net/diccodes.htm
http://forums.corvetteforum.com/show....php?t=2046526
Old Aug 24, 2008 | 09:30 PM
Bill Dearborn's Avatar
Bill Dearborn
Originally Posted by cheez22
Oh, sorry.
Those are history codes. It looks like you may have had a battery problem at one time and the voltages in the door dropped below the required amount. Other than not having your EBCM you don't have any problems.
Bill
Old Aug 24, 2008 | 09:37 PM
cheez22's Avatar
cheez22
Bill
Cool, thanks Bill.
The dealer quoted me over $1200 for a new EBCM installed. Thank goodness for absfixer.com. You can't beat $150.
To What do these codes mean?
